EOS 20D - a first impression...
Discussion in 'General Chat' started by I-S, May 1, 2005.
  1. I-S
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    Last week I got my new EOS 20D, so here's a few impressions after a couple of hundred shots.
    The camera handles like any EOS. This is a good thing. A quick change to Custom Function 4, setting 3 and it handles brilliantly.
    There's a couple of things that I don't like about the handling:
    The shutter button goes click. No big deal you might think, as it does on 99% of the cameras out there, but the EOS 3 and the professional EOS (1 series) have a hair-trigger shutter button that doesn't have a click stop. I much prefer the hair-trigger type.
    The 9-way multicontroller is a bit fiddly and you can't easily and accurately select all focus points. Since I mainly use the middle point anyway it's not that big a deal and I think something that will get better with practice. It is a better system than the EOS 3 had though.
    Beyond those minor points, it's an excellent camera. The output is superb and the resolution is easily on a par with film. It would be nice if the noise was a bit less, or was luminance noise rather than chrominance noise, but as it's at a much lower level than film grain I will live with it.
    A couple of hugely down-sized examples...
    [​IMG]
    This is Suze, a 5 1/2 month old Beagle puppy with a habit of chewing on anything or anyone... This was edited and resized from a medium fine JPG.
    [​IMG]
    The hummingbird was edited and resized from a full-sized TIFF file converted with EVU.
    I-S, May 1, 2005
  2. I-S
    bemcsa
    May 11, 2004
    195
    Leics
    Those snaps a very impresive - and hummingbirds in the back garden too :)
    bemcsa, May 1, 2005
  3. I-S
    lordsummit moderate mod
    3,650
    In the Northern Wastelands
    Global warming. You wouldn't believe how hot it gets in Oldham and Rochdale these days
    lordsummit, May 2, 2005
  4. I-S
    RDD Longterm Lurker
    Jun 25, 2003
    315
    Cheshire
    Impressive pic's :)
    Must say, in my entire life I don't think I've ever even seen a Humming Bird, let alone had my camera with me at the exact moment required to shoot one :eek:
    RDD, May 2, 2005
  5. I-S
    bemcsa
    May 11, 2004
    195
    Leics
    sounds like you need to take your camera to oldham or rochdale, they have flocks of them there :D
    bemcsa, May 2, 2005
  6. I-S
    Jun 25, 2003
    4,842
    In a world of pain
    It's the vultures you have to watch out for.
    [​IMG]
    I-S, May 2, 2005
  7. I-S
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    I picked up an EOS300D on Friday. I know nowt about photography, i feel a stiff learning curve ahead. So far i am very happy with the results.
    penance, May 3, 2005
  8. I-S
    greg Its a G thing
    Dec 30, 2003
    1,687
    Wiltshire UK
    I've got a Nikon F80 and initially assumed lenses would be interchangeable with Nikon D bodies - so the natural option for me (based on this conclusion) would have been the D70 or D100. However if I understand correctly these bodies require digital specific lenses.
    This leaves me with the option to switch to something like the EOS 20D. Can any Canon users tell me why they picked Canon?
    greg, May 3, 2005
  9. I-S
    A0S
    Dec 28, 2003
    122
    London
    Hi Greg,
    The D70 and D100 use any F mount lens.The only change is the Focal length is multiplied by 1.5 so a 50mm becomes a 75mm. Also non AFD lens do not offer all functions but then they don't on the F80 either.
    A0S, May 3, 2005
  10. I-S
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    AOS is correct, also it applies to ALL makes of lenses, not just Nikon.
    Dev, May 3, 2005
  11. I-S
    greg Its a G thing
    Dec 30, 2003
    1,687
    Wiltshire UK
    Ah I see. So my 18mm to 80mm lens will effectively be a 27mm to 120mm? And that's the only effect?
    greg, May 3, 2005
  12. I-S
    rsand I can't feel my toes
    Feb 24, 2005
    903
    Liverpool
    I use standard nikon lenses on my Fuji s2 pro to grat effect, getting real wide is expensive due to the 1,5x magnification. Don't know why they just dont make the ccd's 35mm to avoid this (canon do on the eos 1)
    rsand, May 3, 2005
  13. I-S
    A0S
    Dec 28, 2003
    122
    London
    Contax do a full (35mm) frame CCD as well but at the moment they are very expensive. The reason for the multiplying focal length is the CCDs are smaller than a 35mm frame (About the size of an APS frame, or so I've heard). I would expect to see more full frame DSLRs as the CCDs become easier to manufacture and hence cheaper. But on the other hand it makes telephotos great Sigma 105 to 300mm 2.8 for £500 anyone? :)
    A0S, May 3, 2005
  14. I-S
    Feb 24, 2005
    903
    Liverpool
    Some serious detail going on there BTW Isaac
    rsand, May 3, 2005
  15. I-S
    greg Its a G thing
    Dec 30, 2003
    1,687
    Wiltshire UK
    I have to agree, I love analog gear, but those pics are more than compelling.
    greg, May 3, 2005
  16. I-S
    Jun 25, 2003
    4,842
    In a world of pain
    It's the 100% crop you'll want to see then....
    [​IMG]
    ISO 400, 70-200 F4L @ 200 F4, 1/640th. I do like this lens... sharp wide-open.
    I-S, May 3, 2005
  17. I-S
    Jun 25, 2003
    4,842
    In a world of pain
    Regarding cameras, lenses, etc... The D70 and D100 will use whatever F mount lenses you have for your F80 greg. The DX series lenses will work only on the D series cameras though.
    Sensors.... oh so much controversy surrounds sensors in DSLRs.... CCD or CMOS? Sub-frame or Full frame? 3:2 or 4:3?
    The reason that cameras like the D70 and 20D don't contain full-frame sensors is simply cost. The sensor in the 20D is around 330 mm^2, whereas the full frame sensor in the EOS 1Ds (and mk II ) is 864 mm^2. As the area goes up, the yield goes down exponentially and the price goes up more than exponentially. That's the main reason why the 1Ds costs $8000 as compared to the $1300 of the 20D (yes, the 1Ds body is tougher, weather sealed, etc, but the 1v film body has all these things and is around $1000, and the 1DmkII has the same body as the 1Ds with a smaller sensor and comes in around $4000).
    Making a full frame sensor is only the start though... You have to make it perform well. Kodak made the mistake of trying to produce a full frame sensor without paying enough attention to noise performance, and ended up with a sensor that is pretty much useless beyond ISO160 and is at its best at ISO6. In an attempt to lower the cost they left out the anti-alias filter and so the camera suffers crippling moire effects.
    I-S, May 3, 2005
  18. I-S
    julian2002 Muper Soderator
    5,094
    Bedfordshire
    could they not stitch together 2 or more ccd's to produce a 'virtual' full size one surely the joins could be fixed in software - possibly even 'offline' to improve shot speed?
    or are there other considerations i don;t know about?
    julian.
    julian2002, May 3, 2005
    #18
  19. I-S
    Jun 25, 2003
    4,842
    In a world of pain
    Julian - the old Kodak DCS560 and DCS760 cameras had three 2MP CCDs stitched together to form a 6MP camera. The problem was that the three CCDs could have varying performance, so one might be lower noise than the one next to it, making a noticeable change in the image at the join. That, and those cameras retailed for around 27k meant they never sold very well. Prices are continuing to fall rapidly.
    I-S, May 3, 2005
    #19
  20. I-S
    5,094
    Bedfordshire
    27k :yikes: :mana:
    still there should be ways round the noise issue. i guess depending on the speed of the ccd allowing for multiple grabs for one shot - not sure if this is feasable?. still if you whacked in a big ram buffer you'd not get a huge lag like you do using a memory card.
    still if prices are falling it might be pointless developing clever hard / software solutions to a problem which will be non existant in a year or two.
    julian.
    #20
