Everything required for dedicated mains
Discussion in 'Classified Adverts' started by bourneendboy, Aug 22, 2009.
  1. bourneendboy
    bourneendboy
    Jan 6, 2006
    41
    I was going to install a dedicated mains supply, including a separate consumer unit, but have decided I'll never get round to it. Everything required is supplied to enable a dedicated supply as per Roy Riches 'mains document' which I will include, so very easy to fit.
    The parts are -
    Memera AP4 consumer unit with fitted 100 amp incoming fuse. (suitable for 4 seperate spurs).
    4 - B32 Eaton 32 amp MCB (I also have 4 B50 50 amp MCB if preferred).
    1 mtr long pair meter tails.
    2 - 100 amp single pole connector blocks.
    3 - 8 way earth blocks.
    2 - 2 way double wall boxes (2 single 13 amp sockets fit into 1 double wall box).
    4 - single MK unswitched 13 amp sockets.
    50mtrs - 10mm2 3 way mains cable.
    I purchased all these items approx 3 years ago and they have been stored, unused, in my garage since.
    £100.00 for the lot.
    The cable is very heavy, so will ideally need collecting from my house near Aylesbury, Bucks or delivery service at cost, I guess £15.00 (would need to check)
