Universal player which is outstanding with audio and video formats only 18 months old immaculate boxed with all accessories was £4995 selling £2195 model CDP-300 Frequency response 8Hz – 20kHz balanced +0dB/-0.1dB 8Hz – 20kHz single ended +0dB/-0.7dB (THD + noise) 0.001% ref 1kHz 0.001% ref 10Hz – 20kHz Signal to Noise ratio >107dB (unweighted) Channel Separation 124dB @ 1kHz 112dB 16Hz – 20kHz D/A converter 3 x Cirrus Logic CS4398 Audio Sample rate 192 KHz Output level balanced 4 Vrms Output level single ended 2 Vrms Power consumption 72w audio outputs 6 RCA 2 XLR 1 RCA 1 XLR 1 Toslink video outputs HDMI Component (progressive scan) S Video Composite formats supported CD, CD-R, CD-RW DVD Audio & Video, VCD, SVCD, MP3, WMA, DVD-R, DVD+R, DVD-RW, DVD+RW internal scaling 480i (via all video outputs) 480p (via component & HDMI) 720p/ 1080i/ 1080p (via HDMI) weights & measurements width depth height gross weight net weight mains voltage 17.5†(455 mm) 16.5†(419 mm) (excluding connectors) 4.75†(121 mm) 35 lbs (16 kg) 26 lbs (12 kg) [IMG]http://www.midlandaudiox-change.co.uk/data/images/DSC05480.JPG[/IMG]
