Fact or a lot of **sh
Discussion in 'Hi-Fi and General Audio' started by James_1D, Feb 18, 2011.
  1. James_1D
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    There's a simple way to find out, put gaffer tape over the window and hit the button a load of times until you are utterly lost as to if its on or off. Then listen, and guess, do this ten times. If you manage better than 7 out of 10 then it might well sound different.
    sq225917, Feb 19, 2011
    #21
  2. James_1D
    Dave Simpson Plywood King
    Sep 30, 2005
    395
    Third stone from the Sun
    An alternative is to simply leave the display off and not even worry about it. FWIW, I've never heard anyone comment they thought their CDP sounds better with the display on;-)
    Dave Simpson, Feb 19, 2011
    #22
  3. James_1D
    RobHolt Moderator
    Oct 24, 2004
    Comes down to keeping noise from the display away from the other circuits - if it generates appreciable noise in the first place.
    So good or bad design and it should be possible to eliminate any effect without actually turning off the display.
    RobHolt, Feb 20, 2011
    #23
  4. James_1D
    Sep 30, 2005
    395
    If that's the worst problem my CDS2 has, I'll hang on to it ;-)
    Dave Simpson, Feb 20, 2011
    #24
  5. James_1D
    RobHolt Moderator
    Oct 24, 2004
    Excellent CD player - hang on to it, period.
    #25
  6. James_1D
    Sep 30, 2005
    395
    Will do...it's essentially only three years old. It was completely refurbed from the ground up right before a NANA staffer put it up for sale.
    #26
