Faulty amplifier - replace or repair?
Discussion in 'Hi-Fi and General Audio' started by Mb031162, Mar 16, 2007.
  1. Mb031162
    Mb031162
    Aug 12, 2004
    7
    Cambridge
    A week ago my Denon PMA355UK amp broke down. It's been with a delaer for the last week to find out what the problem is. One side of the amp has blown and needs to be replaced (perhaps a transistor).
    The long and short of it is that it will cost £120 (+£25 that I've already paid to have it looked at) to repair. This seems like a significant amount of money, at my calculation approx. 60% of original cost I paid. You can now get one for £160.
    Should I:
    1) get another quote, £100 seems a lot......
    2) buy a new amp.
    If anyone can recommend for either option I'd be very grateful.
    Budget would be around £200, possibly stretching to £250.
    Music is classical (particularly choral) and jazz.
    Possible options:
    NAD: C320BEE or C325BEE
    ROTEL: RA04
    any suggestions would be most welcome,
    Matt
    _________________
    Arcam CD72T - Denon PMA335UK - B&W DM303
  2. Mb031162
    5,139
    Manchester
    Something similar happened to my old Marantz PM6010OSE, decided to replace it and bought a Cambridge Audio 640A in the same fo £150, it sounds better than my old Marantz.
    I still intend to sell my old amp for £30 :D
    I like to have something new though:)
    amazingtrade, Mar 16, 2007
  3. Mb031162
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    If you like the Denon I'd get a new one while you still can. You may know that it has been discontinued. £120 to repair an amp costing £160 new doesn't make sense to me considering that having spent the £160 you'll have a year's warranty.
    Dev, Mar 16, 2007
  4. Mb031162
    dreftar
    Jan 3, 2006
    490
    Shetland Islands
    You could check out the private ads. There are often great bargains to be had there.
    dreftar, Mar 16, 2007
