Ferrari 458 Italia Revealed
Discussion in 'General Chat' started by Dev, Jul 28, 2009.
  1. Dev
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
  2. Dev
    andyoz
    Sep 18, 2004
    1,117
    Three exhaust pipes?
    andyoz, Jul 28, 2009
  3. Dev
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    I wondered about that too, bearing in mind it's a V8. If you look at the high res images, the middle one looks slightly smaller. For 2 cylinders instead of 3 for the outside ones?
    Dev, Jul 28, 2009
  4. Dev
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    You can have any arbitrary number of tail pipes you like. Almost all car exhausts go through headers into a single catalytic converter, resonators and then may split into separate backboxes or split to separate tailpipes from a single backbox - or even both (eg quad exhausts with twin tailpipes out of each of two backboxes). It bears no relation to the engine configuration in the vast majority of cases.
    I-S, Jul 28, 2009
  5. Dev
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    You are right of course, but it is unusual.
    I guess I was just imagining (the good old days) the exhaust pipe running from the manifold on each bank of cylinders to the silencer box on the either side of the car. The length of each pipe on the manifold and of course the number of cylinders it was fed from being equal (always) and design/tuned to aid the gas flow. Even then the actual number pipes visible at the rear could be whatever the designer wanted, within reason;).
    Dev, Jul 28, 2009
  6. Dev
    Neil
    Jun 21, 2003
    631
    Scotland
    Beautiful! And nice big rev counter at centre of the instruments - fond memories of my old 80's Alfa GTV. . . . .
    Neil, Jul 29, 2009
  7. Dev
    stewbiff
    Aug 28, 2009
    Thanks for the URl provided here
    stewbiff, Aug 28, 2009
  8. Dev
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Dev, Sep 15, 2009
