ferrite rings
Discussion in 'Hi-Fi and General Audio' started by rob, Sep 25, 2003.
  1. rob
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    just ordered 8 ferrite rings, 6 are 25mm and two are 35mm.any ideas where i should put them?
    cheers,
    Rob.
    rob, Sep 25, 2003
  2. rob
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    ive just realised im wide open for abuse here.
    :green: :NADowner:
    rob, Sep 25, 2003
  3. rob
    zanash
    3,826
    Notts.
    Why did you order them ?
    Had you something in mind ?
    IMO they squash the dynamics
    zanash, Sep 25, 2003
  4. rob
    1,964
    well Rob I was going to mention rings of fire.
    I believe these little beasties should only be used if yu actually have a problem. No doub't WM will have more info for you, for myself I wouldn't bother.
    garyi, Sep 25, 2003
  5. rob
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    i heard a lot of good reports about them and thought i would give them a whirl.i suppose with these things experimentation is the key.
    cheers,
    Rob.
    rob, Sep 25, 2003
  6. rob
    technobear Ursine Audiophile
    Jun 22, 2003
    2,099
    Glastonbury
    Bad :green:
    Making it worse :lol:
    technobear, Sep 25, 2003
  7. rob
    6,026
    Beyond the 4th Dimension
    AS far away from your hifi as possible hopefully, in virtualy ever case of equipment we tried using ferrites, either as an OE fit or by putting them on, the dynamics and life is squeezed from the system, however the do seem to enhance the more presenation side of the preformance.
    Example for the day, the CDfix, has a large ferrite just behind the IEC socket, that encompasses both neutral and +(VE) wires, instand up grade, remove ferrite :) and the music returns, with verve, miniumal loss to presetenation, only is a more noticeable when the upsampler is engauged. But as you say, try them, they 'May' have an effect you like. WM
    wadia-miester, Sep 25, 2003
  8. rob
    mr cat Member of the month
    Jul 31, 2003
    3,375
    5
    HI Rob,
    as a general rule - when you should place them on main cables, they will go near the casing of the equipment in question (that is the noisy end of the cable), and not near the mains socket (but you can always experiment!), and on interconnects near the target end (signal goes from source to target), say for interconnects connecting CD player with integrated amplifier the target is integrated amplifier. I tried them on my speaker cables, but I wasn't that impressed…again, you may want to try this and it might work for you.
    :MILD:
    mr cat, Sep 25, 2003
  9. rob
    lowrider Live music is surround
    1,309
    I use ferrites on both ends of TV and digital cable TV mains leads, they do improve the image...
    They came in some power chords I bought for my powers and subwoofers, about 10" from component side, but didn't make any difference I could hear, so I removed them...
    lowrider, Sep 25, 2003
  10. rob
    Hodgesaargh
    Aug 24, 2003
    323
    Edinburgh
    General rule is keep them away from interconnects, but you can use them on power cables and you should get benefits.
    Hodgesaargh, Sep 25, 2003
  11. rob
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    ok they arrived this morning,two of them were shattered into fragments but six remained in tact.
    so first was speaker cables,i put a ferrite per cable at the speaker end. no difference whatsoever.
    next up was my tt phono lead (stock rega 3)
    i dident like the difference.they kind of squelched the sound.
    last was the power leads.
    they seemed to have cleaned the sound up a wee bit.i cant pinpoint it , it just seems to be an overall improvment.
    fiver well spent?
    yes and no....
    yes because they have improved the sound, even if only slightly, and no because two (the two biggest ones as well) arrived in small peices.
    to get best results ive put two at the source end of my amp power cord and also two at the plug end of the same lead.
    ive put a couple on the power lead of my tt and i am still not sure if this has improved the performance of my tt any.
    i will try some on my cdp later and see if i can gain any benefits there.
    thanks for the advice guys,
    Rob.
    rob, Sep 26, 2003
  12. rob
    GTM Resistance IS Futile !
    389
    UK
    I'd be very surprised if they have any effect at all within the actual audio bandwidth.... Ferrite rings will suppress radio frequencies...(at the end of the day they are just very high frequency low pass filters) which would potentially help with noise issues in equipment. One place to definitely steer clear of using them is between a CD transport and DAC.. ferrite rings will cause havoc with the datastream as it is well in to the range that they normally have an effect.
    From a purely technical point of view .. it isn't possible for ferrite rings to have any negative effect on the dynamics of the original signal within the audio bandwidth.. (unless you count subharmonics of radio frequency noise as part of your music) as they just don't work at anywhere near that low a frequency.
    GTM
    GTM, Sep 26, 2003
