I've just tried connecting my mums new digital camera to my computer for the first time. Nikon Coolpix 7900. This is a replacement for a lost 5200. I connected the usb cable and turned it on. Strange, with the 5200 when turning on whilst connected to the pc, the lcd wouldn't turn on or lens extend. The power light would just come on and windows would say it's noticed it. With this, the camera just turned on as normal and windows said nothing. The cable also seemed to get very hot so I unplugged it. I just tried it in another USB port on the pc. Again, the camera turned on as normal. I gave the cable "a wiggle" (camera end), to see if maybe the connection on the camera was loose, and windows said it had found it and started to install. The cable got very hot again so I unplugged it from the camera. I noticed a flame on the end of the cable!!! I had to sort of get under the desk to unplug the cable at the computer end (rear port) and the flame had now grown! I tried another cable and that cable again heated up so I unplugged it straight away. WTF??? So, both cables heating, and the USB hub still worked fine (I plugged printer into it and workeed fine). So, must be the camera. It's a Nikon refurb through an ebay seller, not having much luck with ebay lately :rolleyes: . It has a 90 Day Limited Nikon warranty. I was wedged under the desk when the cable was flaming. Thought it might blow up in my face. I think a refund may be needed. Do I go through the seller, ebay, or Nikon?
