FS Tekni-fi Pre amp
Brought this amp about 1 year ago, it is a Danish amp built by a company making high end equipment in the 90's early 2000. I have had it totally rebuilt by EFG London. All caps resistors and tubes are new. It has 2 out puts one using Audio Note copper caps which cost over £100, the other V-Caps TFTF which cost over £400. The power supply is fully tube regulated with separate tube regulation to each cannel; all caps in power supply are Mundorf Tubecaps with Tubescaps also used in the output stage which cost around £100. The case is all Perspex so is not conductive at all. All resistors are to 1% tolerance. Pot is an Elma stepped attenuator the selection pot is also made by Elma which cost around £250. Has a lot of cotton sleeved silver wire used in output stage. I have also put balance on each output as I as the hearing in one of my ears is not so good. Cost of work alone was £305.
Out performs my £2200 (plus more for mods) Croft Epoch Pre I had before this by a very large margin.
It has only been used less than 200 hours since coming back from EFG London.
This is a line stage only.
Looking for a £850 + shipping.
I thought I had seen this before, just found your thread on Wigwam from June last year.
Out of interest what are the various valves in this pre amp.
Just going to do the school run, will let you know in about an hour as I can not remember off the top of my head.
Power supply has 1xGZ34, 2xPCL805 and 2x85A2. Output has 2x5687. I am using a weber copper cap LINK in place of the GZ34 as these are a better load for the power supply and will make evering thing last for a lot longer, I will supply a GZ34 tube as well who every buys it.
