Furutech e-TP60E AC Power Distributor + Schuko connectors
For Sale: Discussion in 'Classified Adverts' started by Snoopdog, May 31, 2009.
  1. Snoopdog
    Snoopdog
    Apr 12, 2004
    217
    Hampshire
    The e-TP60E is a sophisticated, luxuriously made power distributor that eliminates many common problems found with audio and video components caused by massively contaminated electrical power. The AC waveform becomes severely distorted by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system, plus radiated high frequency digital noise from processors and digital interconnects. There are also distortion products at the top and bottom of the AC waveform created by switch-mode power supplies in electronic devices on the same circuit. Additionally, you're never alone; your residential AC mains supply is shared with other apartments, homes, and businesses on the same utility transformer. That's why many audio and video enthusiasts notice their systems are more enjoyable late at night or on weekends!
    The beautifully crafted special grade aluminum chassis effectively shields against another common problem, RFI (Radio Frequency Interference), and a layer of Formula GC-303 blocks EMI (Electro Magnetic Interference). Internal wiring is FURUTECH μ-14 wire(14 AWG) that guarantees low resistance. Furutech Hyper Quality High Performance SCHUKO sockets are wired to the IEC AC input of the e-TP60E. SCHUKO sockets feature 24k gold-plated Eutectic brass α (Alpha) Conductor, non-magnetic conductors for stable, long lasting, optimized power transfer.
    The Final Result
    The 2-Step Cryogenic and Demagnetizing Alpha Process works in tandem with other design-in features to create the most optimized AC power transfer possible. Furutech's total awareness and devotion to detail results in a greater sense of power, dynamics, and resolution, with cleaner, blacker backgrounds and a larger, more stable soundstage, vivid tonal colors and deeper extension at both ends of the frequency range. The e-TP60 will allow the delicacy, refinement and nuance of a performance through, along with micro- and macro-dynamics that will leave you breathlessly engaged. Displays of all types will exhibit greater, sharper resolution with less ghosting, color shift, “snowâ€Â, or vertical and horizontal lines.
    Formula GC-303
    GC-303 is a special material that Furutech layers and bonds to the interior bottom-plate of the chassis. It actually absorbs EMI (Electromagnetic Interference) generated by the internal fittings of the unit. The e-TP60E uses no other filtering besides GC-303 so AC resistance is kept to a minimum, allowing a more resolving, powerful, dynamic, and colorful performance from your components.
    Many advantages, not least the absence of fuses in the Schuko mains connectors.
    Boxed, new and unused. RRP - 283 Euros. Asking £195.00
    Also available, two high quality Furutech Gold FI-E11 Schuko 250V AC connectors. RRP 43.70 Euros each. Asking £25.00 each.
    Please contact Steve on 01252 695525 / 07725 874832 (Fleet, Hampshire)
    [​IMG]
  2. Snoopdog
    Snoopdog
    Apr 12, 2004
    217
    Hampshire
    Both connectors spoken for!
    Distribution box (£300 new) for sale at £195 ono.
    Snoopdog, Jun 12, 2009
