My dads car has been very juddery lately and I when he drove off today I noticed a huge brown patch on the road where my dads car should be parked. I had a look underneath expecting to a loose oil sump plug or somthing but I found the bottom of the engine block was fine not a sign of oil. I then looked at the gearbox and it was dripping with oil. The whole gearbox is covered in oil. This picture shows some of the gearbox but I couldn't get to the right angle without rsiking getting oil on my camera [img]http://robertson-i.co.uk/project/gearoil.jpg[/img] This is how much oil the gearbox leaked in 15 minutes [img]http://robertson-i.co.uk/project/oileak.jpg[/img] The car is also burning oil which is not surprising, what is this problem likely to be? Could it be the gearbox itself that is cracked? There is a seal which can fail but according to Hayes this is nearer to the drive shaft, the leak appears to be at the front of gearbox. My dad understandably is quite worried as if it needs a new gearbox the car will have to be scrapped.
