Getting rid of my old car
Discussion in 'General Chat' started by amazingtrade, Aug 19, 2007.
  1. amazingtrade
    5,139
    Manchester
    I just can't get the twit to start after trying everything it will turn over but won't go into life and explodes with a load of steam coming out of the front when it almost kicks into life.
    Either way the engine is probably fecked.
    It has 10 months MOT is structurally sound underneath is it possible to get some money for it is a case of paying somebody to collect it?
  2. amazingtrade
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    .......er, AT, I trust this isn't the new one?
    DavidF, Aug 19, 2007
  3. amazingtrade
    Telkman Nurturing Malevolence
    628
    Hampshire
    Assuming you don't intend to fix the problems, I expect your best chances would lie with eBay.
    Do you know what the engine problem is?
    I'd suggest you get a mechanic to look at it. Phone one up, tell them where you are, explain that it's a non runner and you'd like someone to cast an eye over it to see if the repair bill is going to be feasible before getting them to tow it in etc.
    With any luck you now know what the problem is, and can list it as a non/runner in the eBay auction, listing the fact that a mechanic has told you what's wrong with it, along with the fact that it's got a long MOT and is perfectly legal to tow.
    Stick it up at a minimal starting price and no reserve, you'll probably get a couple of hundred for it. If the buyer walks away, try it again, same... claim your eBay fees back and scrap it, you've not lost out.
    If you end up scrapping it, strip any easily removable/desirable parts yourself and whack them on eBay - easy way to make back the cost of an old banger!
    Telkman, Aug 19, 2007
  4. amazingtrade
    mr cat Member of the month
    Jul 31, 2003
    3,375
    5
    um...thats what I was thinking... :rolleyes:
    mr cat, Aug 19, 2007
  5. amazingtrade
    5,139
    Manchester
    No its my old one though my new one has a few niggles so is going into the garage tomorrow to get them sorted.
    I think the problem is sticking valves due to a worn out camshaft. Some mornings it would start first time, toehr times it would take 20 mins, its not starting at all now.
  6. amazingtrade
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Shame if it has 10 months mot then it is saleable from that point of view only.......people will buy a car just for its mot.....but it does need to be running though! If it won't start (IMO) it reduces its value somewhat, although I take someones point about stripping useful bits off it.
    My local scrappie is not short of a bob or two.
  7. amazingtrade
    5,139
    Manchester
    Not taken the rocker of yet but the exploding nose and smoke does not sound healthy, it seems to be from the manifold area, can't see any signs of a hole in the engine block or fluid leakage.
    The last time I had the engine running the chain sounded very rattly but I am sure its not snapped. Mechanically I know the camshaft and piston rings are warn.
    I am just quite bitter because I was just about to put an add in for £250 on ebay which explained the engine will need some work but runs fine but then it didn't start :(.
  8. amazingtrade
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    I'd cut your losses, mate.
  9. amazingtrade
    5,139
    Manchester
    Not even sure what is worth salvaging the alternator, starter, water pump, radiator and gearbox are in great working order, I am not capable of taking the gearbox out though!
  10. amazingtrade
    1,964
    Mate tow it to a scrappy and move on.
    If you are skint as you seem to imply, sell your computer to afford the tow ;)
    garyi, Aug 19, 2007
  11. amazingtrade
    la toilette Downright stupid
    Jan 21, 2005
    1,213
    Somerset
    I'm with Mark, slap it on ebay with an honest description and no reserve, at least it'll be gone and you won't have to think about it anymore. I sold my Espace for 300 notes after the cambelt tensioner went, better than I hoped for for a piece of shit lump of French plastic crap that lost me a grand in only 3 months :mad:.
    la toilette, Aug 19, 2007
  12. amazingtrade
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Thinkng about it again, maybe this si worth a go, from the point of view of the mot.
    At least saves you the mither of getting it dumped....+ you might get a bit extra for it.
  13. amazingtrade
    1,196
    Sunny Cheshire
    Give it the girlfriend.
    Bob McC, Aug 22, 2007
  14. amazingtrade
    5,139
    Manchester
    Sold it for £80, a scrap yard came and collected it ;).
    amazingtrade, Aug 23, 2007
  15. amazingtrade
    Jul 31, 2003
    3,375
    5
    nice one
    mr cat, Aug 23, 2007
  16. amazingtrade
    1,964
    Nice one?
    He bought a piece of shit car that gave him nothing but trouble then sold it for nothing then purchased another piece of shit fiesta?
    Seriously the boy needs his head read.
    garyi, Aug 24, 2007
  17. amazingtrade
    Jul 31, 2003
    3,375
    5
    well, nice one for being able to get rid.. :)
    mr cat, Aug 25, 2007
  18. amazingtrade
    5,139
    Manchester
    Hardly shit, just needed a £60 part apart from that it is mechanically in very good condition and not a single spec of rust any where. Matched with one of the best chassis designs for a small car ever.
    Yes it did go wrong but the car cost me very little in repairs the total cost was £450 for 8 months motoring and 5000 miles and that includes the MOT and servicing.
    Considering you can pay £300 just to get your alloy chip fixed on your range over I hardly think I did to badly.
    I could have got my for my old car but the tax was due the end of August so I had to get rid quick.
    amazingtrade, Aug 25, 2007
    #18
  19. amazingtrade
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    what does that igure include AT...eg fuel?
    if its just repairs you'r talking about....sounds a bit of lump to me.
    .....NOMB of course!
    DavidF, Aug 25, 2007
    #19
  20. amazingtrade
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    I most certainly don't
    #20
