Good secondhand speakers for £6-700... suggestions?
Discussion in 'Hi-Fi and General Audio' started by dunkyboy, Oct 27, 2003.
Thread Status:
Not open for further replies.
  1. dunkyboy
    dat19 blind test terrorist
    Oct 26, 2003
    142
    state side
    It's a 12 step program to accumulate angle iron and glass. You have to tune the glass so it rings and then fiddle with spikes, you do this to pass the time while waiting for a virgin to come along who you will then sacrifice.
    Other uses of Mana allow you to raise your speakers to the point that they are completely off-axis and sound better because of attenuated hf response.
    dat19, Nov 10, 2003
  2. dunkyboy
    7_V I want a Linn - in a DB9
    Aug 7, 2003
    2,013
    Great Missenden, Bucks
    It sounds a little like the approach taken by Clockwork Audio in Cologne. Rather than trying to kill all resonances, they try to tune to a specific frequency. They are also rather partial to C37 lacquer (actually, I use it myself so I'm a bit of a fan). Strangely enough, the Clockwork Audio people believe that the best speaker on earth is the old Celestian SL600 (the aerolam one?) which may partly account for the pretty abysmal sounds that I heard eminating from their showroom when I was there. Despite this, I felt that it was an interesting approach and there could be some mileage (kilometreage?) in it.
    So with Mana you have to wait for the virgin. I believe that with Clockwork Audio she was part of the package.
    7_V, Nov 10, 2003
  3. dunkyboy
    6,026
    Beyond the 4th Dimension
    Steve, I'm sure James will be along to give you full pitch and oustanding benefits of ferrite worship with towers of power, key words here 'Ringer for a Ringer' nothing else comes close for them :)
    wadia-miester, Nov 10, 2003
  4. dunkyboy
    The Devil IHTFP
    Aug 13, 2003
    4,613
    Disco Towers
    It means real-sounding music. Most of you will never get it, which is a pity, but there you go.
    Cheers,
    James
    The Devil, Nov 11, 2003
  5. dunkyboy
    The Devil IHTFP
    Aug 13, 2003
    4,613
    Disco Towers
    The only similar-sounding systems I've heard have all had Mana supports. Systems off Mana are now well-nigh unlistenable to me - just too artificial-sounding.
  6. dunkyboy
    Lt Cdr Data om
    Jun 24, 2003
    1,752
    c37 laquer? is that the stuff you spray on cones to quell break up?
    something maybe not so obvious, there are 2 aspects to bass...depth and volume.
    When you see a speaker response graph, it shows 2 things...the volume, spl or dbs, or amplitude if you like...for this purpose, pretty much the same thing, against the freqency...oh no, shades of flat response again!
    Now generally, a lot of small speakers, esp cheap ones have the bass shelved..posh word for a certain frequency band being stepped up a bit relative to the rest of the frequency.
    This occurs around 70-120 or more hz typically, which gives emphasis to things like low cellos, hand drums. Proac do this by about 3 dbs, and get away with it, as they are clever.
    It can be done with either the box size or the port. Maybe even changing some parameters of the woofer unit itself.
    It gives a nice body and fullness, and a lot of the floorstanders don't do this, they are pretty flat or even overdamped.
    The point I am making, is that a lot of the time, we mix up volume with depth.( and for that matter, the figures are not all like for like) I am sure a lot of speakers are less deep than the figures given, most small standmounts -3dbs 70 hz or so, all of atcs roll of at 40-45hz simulated. Yes even the 150s. However, their roll off is at a higher volume, and will appear to give higher bass levels.
    The proac 3.8s..I want a pair!!, have a boost of a humungous 10dbs or so, and according to some this would be disastrous, but maybe its not just that, having listened to many speakers and studied design a little, the drive units are TOP quality, £110 each, and the port design could be equally if not more impotant, that causes booms as does the room, so as always its a FAR more complex picture than simple measurements or dumbed down mag articles will have you believe.
    So when talking about speakers, remember there is frequncy or depth, and volume at a particular freqency. this can be fiddled by boosting higher up, giving an impression of either fullsome bass or reticent wimpy bass
    Lt Cdr Data, Nov 11, 2003
  7. dunkyboy
    Aug 7, 2003
    2,013
    You generally paint C37 onto cones. It doesn't quell break-up but changes the character of the sound over this region. In A/B tests on paper and aluminium cones I have found that the sound improves (to my ears). The stuff ain't cheap but it's not too expensive per cone either. It's deffo worth a try-out but perhaps not on your most expensive speakers to start with.
    7_V, Nov 11, 2003
  8. dunkyboy
    The Devil IHTFP
    Aug 13, 2003
    4,613
    Disco Towers
    The problem is that Prozac speakers sound like toys in comparison with ATCs.
  9. dunkyboy
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    James,
    sure it wasnt just Prozac haveing an effect;) :D
    penance, Nov 11, 2003
  10. dunkyboy
    6,026
    James, I do believe your been minorly incitive towards the rest of the Z/G population :) Naughty boy
    wadia-miester, Nov 11, 2003
  11. dunkyboy
    Robbo
    2,371
    Berkshire, UK
    At least they have some bass!
    Robbo, Nov 11, 2003
  12. dunkyboy
    merlin
    Jun 23, 2003
    3,262
    Absolutely agree with Devil for once Tony. Proacs do sound like toys, you know the things used by children and liberated women alike to bring joy and happiness.
    ATC's for all their honesty, could never be accused of doing that
    merlin, Nov 11, 2003
  13. dunkyboy
    6,026
    Merlin, quite correct sir, in a more 'Fridgid presentation' :eek:
  14. dunkyboy
    The Devil IHTFP
    Aug 13, 2003
    4,613
    Disco Towers
    Hardly any Robbo.
  15. dunkyboy
    Marco
    Aug 28, 2003
    275
    Wrexham, North Wales
    No, I see you'd far rather try to score points in a useless argument about what happened in the past :SLEEP:
    Btw, I said the issue of your Reference Tops, not the issue with them! There is a difference!!
    However, if you can't be bothered to find out, it's your loss.
    Marco.
    Marco, Nov 11, 2003
  16. dunkyboy
    The Devil IHTFP
    Aug 13, 2003
    4,613
    Disco Towers
    Marco, it's the recent past and I have a long memory. The stands and ref tops I have are set-up perfectly (after four attempts).
  17. dunkyboy
    6,026
    Wow, in fighting between Ferrite abusers cool :) does the winner get a free magnet to 'Pick up the pieces after' :D
  18. dunkyboy
    Marco
    Aug 28, 2003
    275
    Yes, but I'm not talking about set-up.
    Marco.
    Marco, Nov 11, 2003
  19. dunkyboy
    merlin
    Jun 23, 2003
    3,262
    Your spelling gets worse by the day Tony! There is no "e" on the end of ferret, even when discussing the female. And how do you know they don't actually enjoy disappearing up the port on a 50ASL or an orifice of similar dimensions
  20. dunkyboy
    6,026
    'Ferrite' is correct as in 'Iron particles', I feel the Jack and jills of this world wouldn't been see dead, any where that odd twosome :eek:
Thread Status:
