Graaf OTL 20 FOR SALE
Discussion in 'Classified Adverts' started by Colin2040, Jul 12, 2007.
  1. Colin2040
    Colin2040
    Feb 23, 2007
    437
    For sale a GRAAF OTL 20 POWER AMP.
    The GM 2O power amplifier uses an OTL (output transformerless) and OCL (output capacitorless) configurafion. The benefits of this type of circuit are very widely recognised and may be summarised as providing unrivalled transparency, speed and dynamics. A small amount of feedback (6dB) is used to allow the GM 20 to drive even difficult loudspeaker loads without problems. As can be seen from the attached specifications, the performance is of a very high order. For example, the bandwidth extends from 1 Hz to beyond 35OKhz!
    As befits an amplifier of this class, it is possible to use the two inputs L and R in balanced mode by means of XLR plugs or in unbalanced mode via RCA phono plugs.
    Technical Data:
    Output power : 20 W + 20 W RMS
    Output Impedance : 8 ÷ 16 ohms - 4 ÷ 16 ohms mono
    Input Sensivity : 600 mV
    Input Impedance : 50 Kohms
    Total Harmonic Distortion(THD): < 0,4% a 1 W
    CMRR: 60 dB
    Frequrncy Response : da 1 Hz a 350 KHz (-3 dB)
    Damping Factor : 4
    Negative Feedback : 6 dB
    Power Requirements: 105 ÷ 120 / 210 ÷ 240 V (50 ÷ 60 Hz)
    Power use : in riposo 450W
    Dimensions (L x H x P): 350x 215 x 440 mm
    Weight: 22 Kg
    Its in great condition with box,packaging and manual. Postage within UK is included elsewhere please ask. £1450.00
    I'll post pics if wanted.
  2. Colin2040
    Colin2040
    Feb 23, 2007
    437
    I will also throw in a brand new set of power valves.The existing are very good and of goood quality.
  3. Colin2040
    Colin2040
    Feb 23, 2007
    437
    Its worth making an offer .Its a great amp
    Colin2040, Jul 13, 2007
  4. Colin2040
    Colin2040
    Feb 23, 2007
    437
    just in case anybody was going to make an offer its now sold
    Colin2040, Jul 16, 2007
