at the moment i don't have a the cartridge, but i had hooked up the exp head amp to give it some time to settle. there is however, quite noticeable hum. i have replaced my un shielded interconnects between the 2se and the pre and between the exp and the 2se. the tonearm cable is also shielded. between the pre and the power amp the interconnects are still unshielded as is the one between the cd and the pre. all the units except the turntable motor, are run through wm's power master, could that be an issue, tony? graham slee recommended putting ferrites on the speaker cables, near the amp end. does anyone have any thoughts, or better ideas? i don't think the speaker cables are shileded, would this be an option, or benefitial? any ideas? do i have to scratch the slee stuff and try something else?
