Hi all, I have been picky about this subject for a while, it regards noise evident through speakers when the amplifier is on but no music is playing. I replaced an old Classe Audio CA-100 power amp as I thought it was producing too much hiss and hum when connected via RCA, it was evident at a few feet, though reduced to a slight hiss at a couple of feet via XLR. I thought, old amp, needs a service. I replaced it with a Classe Audio CA-101 power amp, which is near identical but a later replacement model, but still there is a slight buzz at the tweeter and slight hum at the woofer via RCA which is reduced to a slight hiss via XLR at a foot or so, this is similar to the noise from the CA-100 and hardly changes when I disconnect either Classe power amp from the pre, or switch all other equipment off but the power. Is this sort of noise normal from high current amps like these, and I am just being picky ? Or could it be noisy mains ? Or faulty equipment ? Another problem I have, when I connect my Teac DAC I get an increase in hum, quite noticeable, and it is reduced when I disconnect the earth connection in the plug. I use Tacima mains blocks with filtering, but the problem changes when I swap the Tacima to a cheap white plastic affair, their is a slight increase in buzz when the pre only is connected which is slightly reduced when I plug the DAC in. Any ideas ? Thankyou.
