Help with speakers
Discussion in 'Hi-Fi and General Audio' started by MikeM, Apr 15, 2011.
  1. MikeM
    MikeM
    Apr 15, 2011
    I have a SHARP mini component system and the spec says:
    OUTPUT POWER RMS 240W (120W+120W) 10%THD
    RMS 160W (80W +80W) 0.9% THD
    What does this (THD) mean?
    SPEAKERS 6 ohms
    SPEAKER input power 120W
    I have 3 sets of speakers in different rooms passing through a COMMTEL 4-way splitter which lets me play any combinations of the 3 sets of speakers.
    I would like to replace the system with a small micro system. Can you advise please on what spec I should look for to accommodate the 3 sets of speakers?
    Also, can I replace any of the speakers with 6ohm or 8 ohm speakers and do I need a certain input power?
    Thanks for your help. You will see that I am not an expert!!
    MikeM, Apr 15, 2011
  2. MikeM
    nando nando
    Jun 1, 2006
    4,017
    london
    T.H.D. stands for total harmonic distortion,
    nando, Apr 15, 2011
  3. MikeM
    nando nando
    Jun 1, 2006
    4,017
    london
    any good mini system will perform well with 6 or 8 ohms, input rating on the speakers is a value close to peking, mini systems i would recomend are TEAC or DENON, imo.
    nando, Apr 15, 2011
  4. MikeM
    Neil
    Jun 21, 2003
    631
    Scotland
    I'd second Nando's recommendation- you won't go wrong with a good Teac or Denon system.
    In your position I might be tempted to buy a Linn Classik (original, go for vgc 2nd hand from e-bay/Gumtree) unless the footprint of a mini system is important to you.
    Neil, Apr 15, 2011
  5. MikeM
    kt66
    Oct 17, 2003
    153
    london
    The Classik's not exactly big! Only a couple of inches wider than say a Denon DM31*
    and the same depth.
    *which I might add has survived 7 years of pure abuse in our kitchen. Bullet proof.
    kt66, Apr 15, 2011
  6. MikeM
    nando nando
    Jun 1, 2006
    4,017
    london
    quote
    having read the thread again you mention "MICRO" ! NOT MINI OR MIDDI? can you be more specific, if you can acomodate the linn that would be a good move.
    nando, Apr 15, 2011
  7. MikeM
    Tenson Moderator
    Nov 12, 2003
    5,947
    Any system that is rated at 80watts RMS ~1% THD will do the job okay. More watts is okay too. Just make sure you only select one pair of speakers at a time. Driving more than 1 pair will give the system a very hard time and could make it go in smoke. To be honest 50watts is probably fine.
    Tenson, Apr 15, 2011
  8. MikeM
    Neil
    Jun 21, 2003
    631
    Scotland
    Less is fine too, depending on on how hard you work the amp - it would be helpful to know which speakers you are using.
    Also have a look at the old "What are watts?" thread.
    Neil, Apr 16, 2011
  9. MikeM
    nando nando
    Jun 1, 2006
    4,017
    london
    Hi neil, i post that thread long time ago but can not find it in past threads, i know that also i had part two,
    nando, Apr 16, 2011
  10. MikeM
    Neil
    Jun 21, 2003
    631
    Scotland
