HiBit Internet Radio
Discussion in 'Hi-Fi and General Audio' started by Labarum, Mar 2, 2010.
  1. Labarum
    Labarum
    Oct 18, 2008
    492
    Labarum, Mar 3, 2010
    #21
  2. Labarum
    RobHolt Moderator
    Oct 24, 2004
    From those above I had a slight preference for the WMA 192 file.
    Seemed to capture the ambiance of the venue slightly better and the strings were less synthetic than on the 128 streams.
    All good though, and I find 128 far better today than in the early days.
    RobHolt, Mar 5, 2010
    #22
  3. Labarum
    Alco
    Nov 30, 2003
    94
    Holland
    Hi DrMartin,
    I'm using a Squeezebox Classic with a DACmagic and it made me forget (and finally sell) my Naim CD5i player.
    It sounds great and has great convenience. I won't go back to a CD-player.
    I have my PC running Squeezeserver in a spare bedroom and my SB in the livingroom.
    It gets his signal from a wireless router, that is connected to my wired modem, tucked away in the livingroom.
    It has never skipped a beat so far, and I think it's great to be able to browse through your entire music collection, with the touch of a button. (on the SB remote in my case)
    regards,
    Alco
    Alco, Mar 6, 2010
    #23
  4. Labarum
    Labarum
    Oct 18, 2008
    492
    Martin, be aware that WiFi has its limits. In most domestic circumstances it is absolutely fine, but if you have a large house or an old one of very solid construction, the WiFi may have insufficient range. If you have such a house you may need to hard wire the Squeezebox. It's not difficult.
    My bungalow in Cyprus has 16" thick stone walls - that is a challenge!
    Labarum, Mar 6, 2010
    #24
  5. Labarum
    DrMartin
    Dec 3, 2009
    89
    Isle of Wight
    Thank you both for the advice.
    I very nearly bought a wireless router & squeezebox yesterday but couldn't work out which squeezebox version I needed / wanted.
    Since I'm not in a hurry I think I'll wait for the 'touch' version.
    As for the wifi signal, my house is only small and the signal will only really have to get through a suspended wooden floor so it should be ok. I would imagine the router has a large part to play in the reliability of all this so I'll be sure to invest in something tried and tested.
    Thanks again
    Martin
    DrMartin, Mar 6, 2010
    #25
  6. Labarum
    Labarum
    Oct 18, 2008
    492
    Good decision.
    #26
  7. Labarum
    semiferger
    Feb 19, 2010
    4
    I tried listening to some internet radio stations on my PC but wouldn't play.
    and I tried it at 192 kbps.I'm using Firefox as my browser.But it wouldn't play.It display different error message.I've no idea how to make it work?
    semiferger, Mar 9, 2010
    #27
  8. Labarum
    Labarum
    Oct 18, 2008
    492
    You tried the 192 D-Dur Stream?
    That a WMA stream and Firefox should call Windows Media Player for that. It may work more smoothly if you use Internet Explorer.
    If you go to the BBC site
    http://www.bbc.co.uk/iplayer/radio
    will they play from Firefox? Or from Internet Explorer?
    Classic FM will only work from Internet Explorer
    http://www.classicfm.co.uk/
    The Classic FM and Radio 3 streams are very good quality.
    If you were to install Firefox's sister
    http://www.getsongbird.com/
    you could access some nice stations with ease, provided your hardware is correctly set up.
    You could play the 256 OGG D-Dur stream in Songbird
    Cut and paste
    http://www.rozhlas.cz/audio/download/ddur_maxogg.m3u
    into Songbird | File | Open a location
    It is well worth experimenting.
    Songbird will not play the highest bitrate OGG-FLAC
    Labarum, Mar 9, 2010
    #28
