Have been pondering a 2M Black for some time - but curiosity says that once you get to that sort of cost (400 +) is it time to look towards MC. Phono stage is that onboard a current Croft pre (ie MM), so needs to be high output - that said, the 25 has what some consider a little too much gain in the first place. Also needs to be fine-line or similar, current cart is a Goldring 1042, before that a 1040 and I seem to get on with that type of profile. It's to hang off a Mørch on a Spacedeck and the most likely candidates look to be a Benz Ace or Dynavector DV20 X2. What do you lot think then?
