Home made equipment isolation platforms.......?
Discussion in 'DIY Discussion' started by Deaf Cat, Nov 1, 2007.
  1. Deaf Cat
    Deaf Cat
    Jun 28, 2007
    119
    London
    Can't quite remember the design Pete put forward after what sounds like a lot of experimentation, only read it once and it vanished:eek:
    I don't want to cause trouble or start dodgy discussions that get removed, I'm just after inexpensive suggestions that people have found to work for them, any thoughts On Designs appreciated, cheers :)
  2. Deaf Cat
    Tenson Moderator
    Nov 12, 2003
    5,947
    I quite like slate floor tiles on sorbothane feet. Looks great with a little oil on the tiles.
    Tenson, Nov 1, 2007
  3. Deaf Cat
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Did you get the pics, Mark?
    AS I say the damping regime was early days; I'm thinking now around combining cones with isolating plinths ,avioding absorbtion entirely and relying on dissipation.
    I rigged up soemthng roughly (far too roughly for pcs!) a few days ago......but it did (IMO) give strong resuilts!
    TBH, i'm basing my idaes around existing designs for now
    eg
    http://www.enjoythemusic.com/Magazine/equipment/0800/brightstar.htm
    though , sand didn't work for me that well
    http://www.cheshireaudio.co.uk/acatalog/Shelves.html
    http://www.silentrunningaudio.com/sra_products.htm
    http://www.stereotimes.com/acc122702.shtml
    I'm not suggesting for minuite you start buying the stuff in the last (or any!) link....but it might give you soem ideas on what you might make?
    I wasn't pulling up the same stuff just now as I was a few nights ago......but with out doubt it is there! Google is your friend!
    What do you think?
    http://myweb.tiscali.co.uk/nuukspot/decdun/
    I also find this a uiseful link......the subject can be confusing.....I think its quite well explained in this passage
    ie the differences in possible construction mataerials
    DavidF, Nov 1, 2007
  4. Deaf Cat
    1,196
    Sunny Cheshire
    get something from Ikea.
    Put kit on it.
    If you must mess about with the legs.
    forget about it.
    Bob McC, Nov 1, 2007
  5. Deaf Cat
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    I think the lad wants to experiment Bob!
    DavidF, Nov 1, 2007
  6. Deaf Cat
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    I would be happy to sell my DIY rack:
    [​IMG]
    [​IMG]
    Just the blue bit, not the granite shelves (you can use concrete slabs for cheaper) and the superspike feet.
    I-S, Nov 1, 2007
  7. Deaf Cat
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Are those part inflated tyres under the shelves, Isaac?
    DavidF, Nov 1, 2007
  8. Deaf Cat
    mr cat Member of the month
    Jul 31, 2003
    3,375
    5
    yeah, I used them to very good effect when I had glass shelves some time back - basically I had them under each component on the glass shelf and the inner tube was inflated so each component sat about 1cm from the shelf...now I'm using a wooden rack - I don't really need it...
    mr cat, Nov 2, 2007
  9. Deaf Cat
    Jun 25, 2003
    4,842
    In a world of pain
    Yes David. In combination with significant mass (ie the granite), they seemed to be very effective for CD players. I did not notice any significant change with other components.
    The idea behind the rack was mass. The frame is solid steel cross-members, with sand-filled uprights, and each shelf was 30mm thick granite. Populated with 4 shelves it weighed in the region of 120kg. At its height it had either a 29" CRT TV or a 30kg NAD S300 on the top, along with my 14kg CD player, etc. Heavy stuff.
    Since my system now comprises of a squeezebox, DAC and monoblok amp behind each speaker, the rack is sat taking up space in the spare room.
    I-S, Nov 2, 2007
  10. Deaf Cat
    DaveHiFi Seeking Nirvana
    Jan 20, 2006
    126
    Bradford
    Isolation
    Having read various threadsand information on isolation my own personal throw is that you make a platform shelf as a composite. Making one ip from bonding differing materials which effect different frequencies say timber glass marble and rubber. In petes recent thread on this he seemed to get better results from combinations. Just a theory and total un researched.
    Dave
    DaveHiFi, Nov 2, 2007
  11. Deaf Cat
    JCL
    Mar 6, 2007
    178
    IMO most of this different materials for supports stuff is hit and miss depending on the specific components used. I think it's all a bit half arsed to be honest. What makes more sense to me is tunable mechanical suspension in tension not compression. Think SME turntable suspension.
    JCL, Nov 2, 2007
  12. Deaf Cat
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    A bit of trial and error/suck it and see is inevitable IMO.
    Is that another way of saying you think its all b*** ***t?
    ...another idea worth following up
    I think that where i've just come from.
    I'm heading towards light and rigid
    DavidF, Nov 2, 2007
  13. Deaf Cat
    JCL
    Mar 6, 2007
    178
    Not at all David. I just think it's not going to work half aswell as a mechanical suspension system of some sort. I'm sure most of the advantages of using different materials for supports with CD players could be bettered by taking the case off and putting sorbothane sheets on the inside of the case.
    JCL, Nov 2, 2007
  14. Deaf Cat
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    take ti to extremes, aerolam, sorbothane and something massy, maybe granite.
    sq225917, Nov 3, 2007
  15. Deaf Cat
    Deaf Cat
    Jun 28, 2007
    119
    London
    Cheers David Interesting links I'm still working my way through them :)
    Quite interesting in that your aproaching from the dissipation method rather than the absorbtion method, would it be, putting it simply, sorbothane absorbing and spike dissipation?
    However what about the vibs that may enter the system from say the speakers, are these dissipated on the way up as the component vibs dissipated on the way down? (does that make sence, two way dissipation?)
    Deaf Cat, Nov 5, 2007
  16. Deaf Cat
    Deaf Cat
    Jun 28, 2007
    119
    London
    Hmmm I've some door stop thick roof slates in the garden, guess they will have a similar effect, may have to locate them for a test, Cheers.
  17. Deaf Cat
    Deaf Cat
    Jun 28, 2007
    119
    London
    Cheers, Yep I heard the legs are now hollow too, and yep I would need to play with heights.
  18. Deaf Cat
    Deaf Cat
    Jun 28, 2007
    119
    London
    It looks like the shelves are welded in position, I'm in need of a little more flexibility I feel, cheers for the offer though.
    Sounds like you've got to the stage I'm heading towards.....some years down the line, for me though ;-)
    #18
  19. Deaf Cat
    Deaf Cat
    Jun 28, 2007
    119
    London
    Thats what I was thinking, so its probably down to ones own choice on what materials sound best, affecting the frequencies that one prefers....?
    This SME thing, only seen pics, is it like, suspended by special rubber bands, hung from pillars in each corner of the TT base?
    Interesting :)
    #19
  20. Deaf Cat
    Deaf Cat
    Jun 28, 2007
    119
    London
    C'on then :) lets see these rough prototypes, very intreging stuff;)
    #20
