How do I make In-Room measurements of speakers
Discussion in 'Hi-Fi and General Audio' started by johnfromnorwich, Dec 27, 2010.
  1. johnfromnorwich
    johnfromnorwich Tannerd.
    Dec 8, 2005
    276
    If I get one of these (or similar):
    http://www.dv247.com/microphones/beh...crophone--5869
    What else will I need? I figure with an ADC, Mic Pre and a copy of Logic (all of which I have) I should be able to cobble something together. Play white noise through speakers? (one at a time ?). Record what's happening in the room? Anything else? As always, any advice is appreciated.
    = John
  2. johnfromnorwich
    Tenson Moderator
    Nov 12, 2003
    5,947
    Get a copy of ARTA
    http://www.fesb.hr/~mateljan/arta/
    Logic isn't made for acoustic measurements, so it doesn't really generate the right test signals or have the facilities to properly analyse the results. ARTA does, and it's free.
    Tenson, Dec 27, 2010
  3. johnfromnorwich
    Dec 8, 2005
    276
    Tenson-Thanks for the link but alas I'm Mac/Linux and it looks to be PC only. I've only just deleted my Windows partition too!
  4. johnfromnorwich
    RobHolt Moderator
    Oct 24, 2004
    9
    Good software and worth running a windows partition for it.
    Its the only reason I suffer windows on my mac :)
    You can make the partition very, very small. OS + 500mb or so for the software.
    RobHolt, Dec 27, 2010
  5. johnfromnorwich
    Tenson Moderator
    Nov 12, 2003
    5,947
    I don't know, but it might run under wine on Linux.
