Lo all, I'm currently in the process of building a few amplifiers to power some 3-way actives. I'll not bore with details on the amps themselves but I do have a question regarding the power switch. I've bought some of those milled finish with inset LED push button types. I believe the brand is Bulgin. Here's the switch: [URL]http://uk.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=4303076&N=0[/URL] And datasheet: [URL]http://www.farnell.com/datasheets/36350.pdf[/URL] OK, so basic stuff so far... My question (finally) is how do I create a simple logic circuit that senses the closed circuit when the button is pressed and activates a relay to power on the amp? Likewise for turning the amp off. If possible it would be nice to have a couple of seconds delayed startup of the amp modules to avoid turn on thumps and the reverse for turn off. I'm a complete electronics idiot BTW. I've built 5 amps and various XO and other circuits but all were kits and simply required soldering - a monkey could be taught to do that. So any explanation will have to be very easy to understand otherwise I just get very confused very quickly :D
