Im after a good pre, but wonder what is the effect it has on the overall sound? What should you spend more on ? Pre or Power and why? Does the pre have an effect on the sound of the power or does the power have an effect on the sound of the pre? and do all power sound similar? Is a power just a dumping of the sound of the pre to the speakers or what?????confused! I recently thought that all pre amps were the same, but after listening to a few there are differences, so whats the gig? What about synergy? can you mix and match pre and powers? tubes and SS? or should they be (like mine are) the same brand?
