I have a fault with my hifi setup and I don't know what causes it. As I mentioned before I use my PC to decode DVD's and then send the decoded info to my preamp where the rest of my kit turns it into happy noise. I had a problem recently where I was getting a hum through the speakers when the preamp was turned to the computer input. When the CD was selected there was no hum meaning everything from that stage on must be ok. Irrespective of which cable I use the hum is there so therefore the cable cannot be the problem. The hum is there if the computer is on or off. The hum goes if the cable is unplugged and return when it is reconnected. I assumed that the card had a faulty connection on the back and sold it. I then recconected the setup using the onboard soundcard...exactly the same problem returned! Does anyone have any suggestions? The only thing I can suggest (merely due to lack of knowledge on the subject as oposed to any rationialisation) is that the 3.5mm stereo jack combines the return path of both channels. Would this be a problem? Please help I have wasted £100s on this problem and cannot place it. Is there anything else i should check?
