Is the current supply of an amp (volts ) more important than the nominal wattage. Does the current supply vary over the frequency range of the amp? How does a valve amps current delivery compare to solid state, ( lowish powered valve amps seem to control loudspeakers far better than they have any right to, is this just 'graceful' clipping or pleasant second hamonics ) thanks.
