Interconnect
Wanted: Discussion in 'Classified Adverts' started by buffalosoldierz, Feb 2, 2004.
  1. buffalosoldierz
    buffalosoldierz
    Jan 3, 2004
    15
    London
    After more than a year, I am still yet to really hear my system, because I am still using the freebie interconnect that came with my CD player. Please excuse my student peasant-ness. If anybody has anything they could mercifully offer for £15 inc. delivery I would be eternally indebted. Thank You.
  2. buffalosoldierz
    buffalosoldierz
    Jan 3, 2004
    15
    London
    It was probably a bad move to be scrounging on my first post, but such is the height of my desperation.
  3. buffalosoldierz
    zanash
    3,826
    Notts.
    Why not take a look at the DIY section and have ago at the zero cost IC !
    zanash, Feb 3, 2004
  4. buffalosoldierz
    PBirkett VTEC Addict
    2,456
    The Toon
    Why not just go to Richer Sounds or Dixons and get one for £15?
    PBirkett, Feb 3, 2004
  5. buffalosoldierz
    liamjf
    186
    LONDON
    Try a search on EBAY, you can usually pick up cheap I/Cs on there.
    Liam.
    liamjf, Feb 3, 2004
  6. buffalosoldierz
    buffalosoldierz
    Jan 3, 2004
    15
    London
    Thanks for your replies. I was looking for some cheap second hand cable. I'd be pretty useless at any DIY work, but'll consider it if nothing comes up on ebay, which i'll keep an eye on for the next few days. Also, does it effect performance if an interconnect is used second hand?
    buffalosoldierz, Feb 3, 2004
  7. buffalosoldierz
    MO! MOnkey`ead!
    4,881
    Sounds like a deal for someone! They send you a cable, get £15 or so for it, and you're forever indebted to them! Swopping your soul for cable is taking things a little far I think. :p
    Welcome to the forum btw. :D
    As for will it effect it because it's second hand. Some will say no, and some will say yes. And those who say yes will MOst likely say "yes, for the better", believing it's been burnt in and thus will sound better! It'll be cheaper for sure though! :D
    MO!, Feb 3, 2004
