Is anone having trouble getting here?
Discussion in 'Hi-Fi and General Audio' started by garyi, Sep 28, 2003.
  1. garyi
    1,964
    I don't know if its me or what but quite often recently Ican't get to this forum, it says the network connection was reset because the server was busy, or server not found?
    am I alone?
    garyi, Sep 28, 2003
  2. garyi
    PBirkett VTEC Addict
    2,456
    The Toon
    No problems here.
    PBirkett, Sep 28, 2003
  3. garyi
    mick parry stroppy old git
    Jun 21, 2003
    557
    Swindon
    Gary
    If I remember correctly, you are on broadband which is prone to a dropping of power on the LAN settings.
    Ring your technical helpline, because what you have is the classic symptoms.
    Regards
    Mick
    mick parry, Sep 28, 2003
  4. garyi
    adam
    443
    spain
    I'm on broadband too,and get the same problem,"cannot find server",like as mick says the power drops,a real pain.
    adam, Sep 28, 2003
  5. garyi
    5,139
    Manchester
    if it fails to load up try typing:
    http://www.zerogain.com/forum?
    The question mark at the end of the URL is very important as it resets the DNS request in a browsing session, so if a site fails to load doing that some times solves it.
    I'm on broadband too, well ADSL to be exact, but I have had no problems with Zerogain not loading but I have had problems with some other sites.
    amazingtrade, Sep 28, 2003
  6. garyi
    2,456
    The Toon
    I'm on broadband, no problems still....
  7. garyi
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    asdl
    no probs here.
    just to rub it in.......he he.
    Rob.
    rob, Sep 28, 2003
  8. garyi
    zanash
    3,826
    Notts.
    You guessed it
    yes I'm having that problem as well as the posting problem.......I'm on broadband too
    Whats this about the question mark ......I'd like to know more
    zanash, Sep 28, 2003
  9. garyi
    1,964
    I have been spaking with NTL, amazingly I got through in 30 seconds today!
    anyhoo we did all sorts of stuff, pings and traceroutes etc.
    We could not find anything wrong per say. As it goes I have been having alot of trouble aorund the web. He suggested it could be something to do with the balster worm and the amount of firewalls requesting info right now. He said they had been getting problems from american website still.
    He took me through everything it could be and my connection is good, so I am at a loss really. I have specified DNS server adresses to see if that helps.
    The guy did suggest that some people go onto the web and find server addresses to use which sometimes are better.
    He was in no way saying Ishould try that, but only that people do.
    Any ideas what the hell he was on about!
    garyi, Sep 28, 2003
  10. garyi
    davidcotton prog rocker, proud of it!
    Jun 22, 2003
    182
    Dorset
    No problems here either.
    davidcotton, Sep 28, 2003
  11. garyi
    5,139
    Manchester
    I can't remember exactly what the question mark does but when you type in the address www.zerogain.com/forum in the browser it then looks under the .com DNS (domain name server) which is a large database of domain names and their IP addresses to the servers the website is hosted on. So when you type in www.zerogain.com it looks up the DNS server and finds the IP address for the server.
    Some times I am not sure why when you type a URL in the it dosn't get the information from the DNS server properly thus the browser dosn't know the IP address so cannot display anything.
    When you place a question mark after the URL it forces the browser to look up the DNS server again, where is if it you just retyped it the DNS is data will be stored in your cache on your hard disk so may not work correctly.
    Thats the easiest way I can explain it, its a more complex than that, and what I said above my not be quite true, please can somebody confirm that.
    I am not sure why these erros in the first place happen though, I would think its an ISP problem. Also many on many servers you can block IP addresses (this happened to me once before, I was banned from a website as a joke).
  12. garyi
    zanash
    3,826
    Notts.
    thanks for the info........I'll think about next time I use the browser !
    zanash, Sep 29, 2003
  13. garyi
    julian2002 Muper Soderator
    5,094
    Bedfordshire
    gary,
    due to bandwidth sharing and ntl broadband's policy of not upping bandwidth until a certain number of people in the area have signed up you may be encountering the '6 o'clock phenomenon' this is when all the kiddies in the area have had their dinner, watched neighbors and log on to surf for porn and chat in paedophile ridden chat rooms. if i try to do anything between 6 and 9 o'clock that involves the internet it takes an age and i;'ve got the 1meg connection. usually i just turn off, watch the simpsons and pie in the sky and then log back in for a quick check before bed.
    julian
    julian2002, Sep 29, 2003
  14. garyi
    Jun 21, 2003
    557
    Swindon
    Gary
    Right Click on my computer
    then left click on properties
    then left click on performance.
    Your system resources should be at least 70%.
    If it is lower, reboot and things will move faster.
    Regards
    Mick
    mick parry, Sep 29, 2003
  15. garyi
    1,964
    Mick you are a star. However I have far more taste than you and have an Apple computer, which apart from being better than any fart arsed put together propriatery dated PC crap, also looks stunningly good.
    Don't worry when you next look towards a PC purchase, you will get a mac!
    garyi, Sep 29, 2003
  16. garyi
    condyk
    Jul 5, 2003
    57
    Bath & London
    Does this mean that if you'd have had a PC then you'd have cured the problem by now? LOL!!!! Don't worry, I'm a Mac fan myself who is 'foced' to use PC's day in and day out! They're both great compared to chalk, slate and abacus!!!!
    Anyway, either reboot and try if the same problem occurs with other sites; disconnect and connect to ADSL line often cures problems. If only happens on Zerogain site then try all the above.
    condyk, Sep 29, 2003
  17. garyi
    1,964
    Well its all rather random, and NTL have fessed up that they are working on one of their servers.
    It seems to be a bit better now.
    garyi, Sep 29, 2003
