Is *signal purity* BS?
Discussion in 'Hi-Fi and General Audio' started by Gerner, Dec 29, 2007.
  1. Gerner
    ShinOBIWAN
    Jun 7, 2006
    710
    The same would apply to any min phase crossover transfer function you care to mention. Doesn't matter whether its Linkwitz, Butterworth or whatever else.
    Its really a short paper on IIR vs. FIR filtering with a few of his correction algorithms thrown in.
    EDIT: There's also an error in that paper because the butterworth filters aren't showing the correct transfer function that a genuine butterworth network produces.
    ShinOBIWAN, Dec 31, 2007
    #41
  2. Gerner
    ShinOBIWAN
    Jun 7, 2006
    710
    Yes, give Alex my regards when you see him.
    There's many bright folks in audio but Alex is one of the brighter ones and also takes time out to take an interest in small independent efforts such as that of a DIY'er.
    He's got himself a steady customer here and I'll certainly be using his HF driver expertise for my next project in '08.
    Thankyou and likewise on your own design.
    #42
  3. Gerner
    endust4237
    Dec 22, 2006
    38
    Let me know when you have a chance and you are welcome here of course.
    endust4237, Dec 31, 2007
    #43
  4. Gerner
    Gerner
    Aug 31, 2007
    108
    Hi Shin
    First thanks for briefing me.
    I know from my PC-player world that i can double the data as *many* times as I would care for.
    You gave me the answers. I do not need to jump for a 64 bit MOBO where no programs available hardly can work. But it will be useful for the course of processor duties. Right?
    I have a 32 bit MOBO with quadro processor. + a bunch of PC's and Laptops. Yes 6 of them.
    Yes I know Dr. Ulrich Bruggemann has been contributing to TACT.
    I just pointed out he could have illustrated his enourmous capabilities and knowledge, not holding up his theories against a stupid Butterworth equation. He came around that part a little too easy.
    He could at least compare his program to this:
    http://www.linkwitzlab.com/crossovers.htm
    and we all know this as well:
    http://www.linkwitzlab.com/stereo reproduction.htm
    this is another approach to filtering not hurting my BS, but still adds components in the chain and remove fewer in the passive filter:
    http://www.linkwitzlab.com/filters.htm
    And no, I do not link up to Siegfried. Don't know the guy at all.
    Having said that, I have the deepest respect for Dr. Ulrich Bruggemann.
    I will give his program a try and report back when I am done.
    That may take some time..:D
    Thanks once more Shin and Mike.
    Gerner:)
    Gerner, Dec 31, 2007
    #44
  5. Gerner
    Gerner
    Aug 31, 2007
    108
    Thanks endust....are you the guy in Budapest...and then know Ferenc?
    I just ask, because all those nick-names on forums are hard to identify who's behind.
    Gerner:)
    #45
  6. Gerner
    Gerner
    Aug 31, 2007
    108
    I noticed...
    Gerner :)
    #46
  7. Gerner
    Gerner
    Aug 31, 2007
    108
    I shall hug Aleks from you.
    He is my cup of tea. :)
    What we are to try out is not exactly a DIY project...but beyon that scale (positively meant of course).
    But if it works out well, we are talking about a completely new ribbon which combined represent a 45 x 160 cm 216 ribbon 16 x 200 mm horisontal bended ribbon surface element, enclosing 20 kg's of neodymium and a new magnet structure without visible anchor and a new suspension technique. Flux control above anything seen before. > 1 Tesla in the gab.
    Efficiency around 107 db/w/m. Cut off at 500 Hz. No trafoes involved.
    On top of that it will be an open baffle system.
    Oh... the basses...wait and see. Hehe :D
    Gerner:)
    Edit: The Swings is not my design, but my theories are found inside there. The design and all rights belongs to Bert.
    #47
  8. Gerner
    ShinOBIWAN
    Jun 7, 2006
    710
    In Jan 07 Alex sent pictures of a prototype he was working on. It consisted of multiple dipole ribbon elements in close formation along with neodymium slugs built into the framework/magnetic circuit. The whole thing was on a pivot mechanism that could be adjusted to create a wider dispersion pattern.
    I don't think he ever finished it as he got busy with more important commercial developments. It certainly looked interesting though.
    I was thinking about having something custom built from him for my next attempt. Romy seems pleased enough with his teardrop 109dB high efficiency ribbon although that's not the direction I'd be interested in going but does show Alex' designs are fairly flexible.
    #48
  9. Gerner
    Gerner
    Aug 31, 2007
    108
    Shin, yes this is the THING, but further developments are applied since those pics were published by Aleks.
    The efficiency is still to be determined soon. It might as well be 112/db/w/m, as we don't know yet what the stacking will do to us and when the imp. ratio of the trafo is out of the game, only maths can tell. I was very concervative naming the efficiency. Undersell----overdeliver is my codex.
    But let's see.
    What is important is, that this huge surface flash fast multiple element can go so low before high-pass filtering is applied. Amazing...:)
    A two way system showing piston qualities and giving a damn about time alignment. At least for the ribbons part.
    Basses will be averaged.
    I think *you* know what I mean.
    But if it works out well, then it will be a comercialised system and not a DIY.
    Pricetag > at least 100.000 £ :MILD:
    Cheers....
    Isn't it about time to celebrating a little now...???
    You have very little left of 2007 your place.
    Gerner :)
    #49
  10. Gerner
    endust4237
    Dec 22, 2006
    38
    Yep, I am :), it is not a secret at all.
    #50
  11. Gerner
    Gerner
    Aug 31, 2007
    108
    :D:D:D:D:D:D:D
    Pa onda vidimose...
    Sve najbolje zele na Beogradu.
    Puno Poztravi iz
    Gerner:)
    #51
  12. Gerner
    joel Shaman of Signals
    Jun 21, 2003
    1,650
    You're really full of yourself and full of it.
    My first New Year's resolution: Avoid the Green Ink Dragons and their lairs. Cheerio
    joel, Jan 1, 2008
    #52
  13. Gerner
    Gerner
    Aug 31, 2007
    108
    Feel free to do so.
    http://www.worldwidewords.org/qa/qa-gre5.htm
    Gerner:)
    Gerner, Jan 1, 2008
    #53
  14. Gerner
    Nomoretweaks Tourist on tilt
    Dec 9, 2004
    265
    Richmond
    To put it shortly, the main purpose of the "shortest track" or "pure signal" is preserving the microdynamics which are the weakest link of most good systems. Screwed microdynamics, above all, rob the music of it's emotional context. EQ deals with other things, mainly freq. responce. But the thing is - we humans adapt to tonal deviations much more easily than to dynamic ones. That's why equalised music often sound "right" but dull. I have used it all - from parametric to TacT, and have no intention to come back to it.
    Nomoretweaks, Jan 1, 2008
    #54
  15. Gerner
    tuga
    Dec 4, 2006
    324
    3
    Oxenaforda
    Why would you want something other than the purest reproduction of what's in a recording?:rds2:
    • Because many recordings are poor, overly compressed, and need some kind of "tweaking".
    • Can that be done without adding harmfull distortion? (I don't object to a little "euphonic" distortion as long as it makes the poor recording better)
    • Well, I can't answer that :D... But you can either use some kind of tone adjustment or a "flavoured" piece of gear.
    • This second option seems to be the worst alternative since it might have a negative effect on good recordings.
    And how about "contrast"?:confused:
    • Could you add contrast to flat and liveless recordings by replacing, say, the speakers?
    • Or maybe have two systems with different flavours?
    ___
    Of course all this BS only applies to those who wish to listen to the music...
    Those who would rather listen to the recording should stick to ruler flat response gear.:Quad:
    P.S.: My gear goes for the smallest number of parts, shortest signal path to, as Nomoretweaks says, "preserve the microdynamics"
    tuga, Jan 1, 2008
    #55
  16. Gerner
    anubisgrau
    Mar 24, 2006
    663
    excellent thoughts, pretty much mirroring my recent findings. superior microdynamics are the main reason IMHO why some unlinear speakers (different fullrangers in the first place, and some horns to lesser extent) sound so exciting and emotionally superior despite a flawed frequency response.
    i've recently had a thrilling demo at teresonic, a manufacturer of rather excellent lowther based cabinets - in their system (consisting of their own CD player and 300b IST SET with a mercury vapor rectification), the signal is passing only through 7 elements in total (valves, resistors, transformers, not a single cap) between the laser pickup and the membrane of the lowthers. a truly remarkable sound full of explosive microdynamics and emotional content: you just stop thinking about lowther shout, lack of deepest bass etc.
    nomoretweaks, would you mind sharing us details on your system (in particular - loudspeakers)
    anubisgrau, Jan 1, 2008
    #56
  17. Gerner
    ShinOBIWAN
    Jun 7, 2006
    710
    And that is a perfectly valid method. Good on you for being so passionate about it.
    Its all hot air talking about what works and what doesn't and it also seems a number of folks here haven't heard EQ done well. Rather than continue down a well beaten path, I'd be happy to have any fellow enthusiasts as guests should you wish to hear a decent implementation of digital room correction. The only real way to judge a method is to hear it done to a high standard.
    An observation; I remember about a decade ago when audiophiles were strongly adverse to physical room treatments. They are now seeing their way into the best setups around the world. Maybe in another 10 years time the same will be true of digital crossovers and correction. Already studios are using this technology just as they adopted physical treatments early on.
    BTW Happy new year to all :)
    ShinOBIWAN, Jan 1, 2008
    #57
  18. Gerner
    6,766
    bucks
    " Is Signal Purity BS ? "
    Pretty much everything written by self aggrandizing audiophiles is BS.
    It's a wallet orientated cock fest of bollocks.
    Me included ;)
    bottleneck, Jan 1, 2008
    #58
  19. Gerner
    ShinOBIWAN
    Jun 7, 2006
    710
    :D
    Can't disagree with that.
    Oh and me too! ;)
    #59
  20. Gerner
    Gerner
    Aug 31, 2007
    108
    Maybe not spill more green ink here this time.
    However I would like to hear your system Shin.
    May I PM you once I come around UK this year?
    Gerner
    Gerner, Jan 1, 2008
    #60
