I've disconnected the cartridge tags as I'm getting no signal in the left channel or only intermittent. At the other end of the arm tube is a small trailing connector block with brass pins as the armtubes on the Hadcock are swappable. Putting the multimeter terminal probes at the ends of each wire in turn I get a reading from the red, white and green, but nothing from the black. I know the carts fine, so does that mean the arm tubes cooked? I'm not that technical!
