Just white noise
Discussion in 'Hi-Fi and General Audio' started by Hodor69, Aug 11, 2024.
  1. Hodor69
    Hodor69
    Aug 11, 2024
    3
    Hey, any ideas??
    Receiver (hk3390) has white noise only through all inputs plugged in or not…. Headphones or speakers…. Have performed resets, but still only noise. Any ideas anybody?
  2. Hodor69
    Sergeauckland
    May 31, 2012
    434
    87
    Suffolk
    As you haven't had a useful answer, and I hate seeing enquiries go unacknowledged, at least I would reply.
    The only idea that came to me is that if your unit has been stored for some time, say a couple of years, it could be that there's a backup battery that stores settings that has gone flat. Otherwise, I have no idea what could be the problem, as you have said you've reset it.
    Also, how loud is this white noise? A very gentle hiss, or a loud roar? If very quiet, could be a hardware or software failure that's stopping audio getting to the output. If loud, that points to a software failure that's screwed up digital audio data.
    In either case, if you've checked any troubleshooting hints in the manual, you need go get a tech to look at it. It's not something we can diagnose remotely unless it's a common fault with an easy remedy.
    S
    Sergeauckland, Aug 12, 2024
  3. Hodor69
    Hodor69
    Aug 11, 2024
    3
    Hodor69, Aug 14, 2024
  4. Hodor69
    Arkless Electronics
    Sep 7, 2016
    148
    69
    Yep sounds like a digital fault. Not repairable.
    Arkless Electronics, Aug 14, 2024
