Finally got my KAB EV-1 on the weekend, and have been busy trying to perfect my technique. Whilst the results are getting better, they are not perfect yet! I was hoping some more experienced users may be able to answer a few questions: 1. However hard I try the KAB will not dry the outside edge of the record - has anyone else found this, or am I just doing something wrong. The start of each record I have cleaned sounds awful! 2. How much fluid should I use? I have found that using more, and leaving the record very wet after the initial scrub seems to yield less cloudy results. 3. What vacuum power should be used? I have a very powerful Miele cleaner that will operate anywhere between 300 and 1800RPM. I have found that results get better the more power that I use, but I havent dared to use nmore than 1200RPM for fear of warping my vinyl. 4. Does anyone use anything other than the supplied brush for the initial scrub? I have found that the machine is excellent and removing dust and static, but struggles with fingerprints etc? Any advice appreciated!
