[URL="http://gpoint-audio.com/kbl-sound-supporting-footers-trial-is-now-on/"][ KBL Sound supporting footers trial is now on ! ;][/URL] [IMG]http://www.kblsound.pl/images/obrazy/Absorbery01.jpg[/IMG] [B]We are pleased to announce that KBL Sound footers trial had been just started. Please keep your eye on the thread to gain more knowledge about, as soon first independent opinions will be posted here. So far please read bellow what the manufacturer himself declares about their efficiency ; ][/B] [I]Proper isolation of audio equipment from vibration has a positive impact on all parts and their loss-less operation, resulting in more direct music transfer and better tonal balance. KBL Sound Big Foot parasite vibration absorbers are the result of long-term comparison of different design and material solutions. They are made of a special alloy enriched bronze filled with two components, which absorb vibrations very effectively. Big Foot absorbers can be used under all devices and loudspeakers, but the largest effect is quite spectacular when used with sound sources (CD, DVD, DAC) or preamplifier. An improvement in sound energy and resolution becomes immediately noticeable. The colors become more saturated and all instruments are given clearer contours, and are better separated from the background. It seems to be more air around them. [/I] The set contains 3 pieces of identical footers. They have no load limits. Dimensions are following : [B]Diameter 69 mm, height 37 mm.[/B] [B]Weight: 2 lbs bronze, 1lb aluminium[/B] [B]Price is £ 320 per bronze set and £ 220 per alloy set.[/B] All of you Gentleman who would wish to join this trial , please contact us. The list remains open and we are interested to gain as many beta tester users as possible. Conditions will be mailed back to interested parties. Txs;)
