Krell KRC HR pre amplifier with phono stage
Discussion in 'Trade Adverts and Discussion' started by wadia-miester, Nov 12, 2014.
  1. wadia-miester
    6,026
    Beyond the 4th Dimension
    Krell's ubiquitous muscle house the 300FPB (full power balance) highly desirable power amplifier. In good condition drives pretty much any speaker you care to mention with aplomb . No box / crate with this beast, so pick up only demonstration no problem. New cost £9500
    Asking £2395
    Specifications
    Krell FPB 300 Power Amplifier Specifications:
    * OUTPUT POWER
    … 8 Ohms 300 W
    … 4 Ohms 600 W
    … 2 Ohms 1200 W
    * FREQUENCY RESPONSE: 20 Hz to 20 kHz +0 dB, -0.05 dB
    * SIGNAL TO NOISE RATIO: 113 dB A Weighted
    * TOTAL HARMONIC DISTORTION:
    … 1kHz < 0.03%
    … 20 kHz < 0.16%
    *INPUT IMPEDANCE: 100 kOhms
    * INPUT SENSITIVITY 2.34 Vms
    * INPUTS:
    … 1 pair balanced via XLR connectors
    … 1 pair CAST via 4-pin bayonet connectors
    * OUTPUTS: 4 pair Speaker Binding Posts (upper left, lower left, upper right lower right)
    * DIMENSIONS
    … Width 19.0”
    … Height 10.3”
    … Depth 17.0”
    Weight 90lbs
    Review 1
    http://www.coherent-systems.co.uk/contact.asp
    [​IMG]
