Landfill full of capacitors
Discussion in 'Hi-Fi and General Audio' started by RobHolt, Aug 18, 2010.
  1. RobHolt
    RobHolt Moderator
    Oct 24, 2004
    Could be heat, or it has lots of ripple across it, or both.
    RobHolt, Aug 20, 2010
    #21
  2. RobHolt
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    Lots of failing caps coming out of China these days.
    sq225917, Aug 20, 2010
    #22
  3. RobHolt
    Paul Ranson
    Sep 4, 2003
    1,602
    An octopus's garden.
    That's 26000 hours.
    If you look at some capacitor datasheets then, for small electrolytics, at their rated voltage and ripple current, the basic lifetime is between 10000 and 30000 hours. These obviously get longer as you reduce the temperature, voltage and current and you can calculate the implications.
    IMO it's not really surprising in a cheap bit of kit used continuously to find a failure after 3 years. I would guess the warranty is a year...
    (I looked at a couple of http://www.kemet.com/kemet/web/homepage/kechome.nsf/weben/products#lea-ele )
    Paul Ranson, Aug 20, 2010
    #23
  4. RobHolt
    Joe Petrik Denebian Slime Devil
    Jul 17, 2007
    121
    I contacted Lockwood Audio some months ago to ask whether the caps in the GRF's crossovers were overdue for replacement. Lockwood said not to bother, as they'll be fine even though they're 50 years old.
    Does this seem likely?
    Joe
    Joe Petrik, Aug 20, 2010
    #24
  5. RobHolt
    Labarum
    Oct 18, 2008
    492
    I got the same advice from MB Quart about my big floorstanders.
    "Unless something is obviously wrong, leave it alone." was what was said.
    Labarum, Aug 20, 2010
    #25
  6. RobHolt
    Richard Dunn
    Jul 5, 2006
    1,198
    Yes, and the probable like for like replacement will not be as good as the originals.
    Richard Dunn, Aug 20, 2010
    #26
  7. RobHolt
    nando nando
    Jun 1, 2006
    4,017
    london
    my caps on my tannoys are over 30 years old , i did not change them but have done internal wiring differently than tannoy,
    nando, Aug 20, 2010
    #27
  8. RobHolt
    Jul 17, 2007
    121
    Richard,
    How so? (the bit in bold)
    Joe
    #28
  9. RobHolt
    BlueEyes
    Jun 29, 2010
    15
    Paul, when do you anticipate the capacitors on your ATC 50 active speakers will require replacing?
    BlueEyes, Aug 20, 2010
    #29
  10. RobHolt
    Richard Dunn
    Jul 5, 2006
    1,198
    When it doesn't work properly.
    #30
  11. RobHolt
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    In what form?
    SMT?
    The products i am involved with have the PCA assembled in China and we do see quite a few SMT caps popping clogs early.
    Early stages of analysis at the moment but it looks like it may be due to the extra heat required since we all went lead free.
    penance, Aug 20, 2010
    #31
  12. RobHolt
    Paul Ranson
    Sep 4, 2003
    1,602
    I don't know. I hope they will go 10 years without significant degradation.
    Compared to NVA or Naim these caps run at higher temperatures and currents.
    #32
  13. RobHolt
    BlueEyes
    Jun 29, 2010
    15
    As Richard appears to suggest, presumably, there is no 10 year period and I assume as these are industry work-horses they will last longer than most comparable speakers before the capacitors need replacing? 20 years?
    #33
  14. RobHolt
    RobHolt Moderator
    Oct 24, 2004
    The 10 year period seems to be a Naim thing - a standard recommendation that everything be re-capped if over 10 years old.
    RobHolt, Aug 23, 2010
    #34
  15. RobHolt
    Richard Dunn
    Jul 5, 2006
    1,198
    i.e. to fleece the sheep.
    Richard Dunn, Aug 23, 2010
    #35
