Latest Must Have accessory ...
Discussion in 'Hi-Fi and General Audio' started by Uncle Ants, Aug 9, 2006.
  1. Uncle Ants
    Tenson Moderator
    Nov 12, 2003
    5,947
    Tenson, Aug 9, 2006
    #21
  2. Uncle Ants
    andyoz
    Sep 18, 2004
    1,117
    Has anyone here "in the trade" got any idea of actually how many of these devices they might shift in the UK?
    10, 100, 1000?
    andyoz, Aug 9, 2006
    #22
  3. Uncle Ants
    KUB3 ciao
    Feb 20, 2006
    278
    When you've realised it's all pap, try using it as a demagnetising fruit bowl. Remember to report back on the fruitiness.
    KUB3, Aug 9, 2006
    #23
  4. Uncle Ants
    Dec 5, 2003
    1,928
    East Midlands
    I'm in the trade ... but haven't a clue. I can give you an estimate of how many I'd likely sell If I carried them ... a big fat zero would be my guess. I don't think any of my customers would be daft enough ... but then I'm not what you would call a high end dealer :) Maybe the really high end dealers have more customers like that arf :D
    #24
  5. Uncle Ants
    RobHolt Moderator
    Oct 24, 2004
    9
    Can you fry bacon on it?
    RobHolt, Aug 9, 2006
    #25
  6. Uncle Ants
    Dec 5, 2003
    1,928
    East Midlands
    No but you can demagnetize it, thus breaking down the cholesterol into smaller molecules and making it healthier
    #26
  7. Uncle Ants
    nsherin In stereo nirvana...
    728
    Portsmouth, UK
    Interesting that they mention that it can demagnetise MiniDiscs. Considering MiniDisc technology is effectively magneto-optical, I'd have thought it would screw up the contents of the discs!
    nsherin, Aug 9, 2006
    #27
  8. Uncle Ants
    RobHolt Moderator
    Oct 24, 2004
    9
    Persumably it works better if positioned on a non ferrous platform like Quaraspire or Hutter - interference with the field and all that?
    Will it be safe on Sound Org, Target and Ma ....... that other metal one?
    #28
  9. Uncle Ants
    SCIDB Moderator
    2,501
    Vinyl IS Magnetised.
    Every thing is magnetised. There are more than one type of magnetism.The normal type that everyone thinks of is Ferromagnetism.There is also Paramagnetism. All materials are Diamagnetic.
    Diamagnetism is a form that occurs in a substance when a external magnetic field is appiled. The degree of magnetism (magnetic permability & magnetic suseptability) can be very low. If you compare Mumetal with say water, there is a huge difference.
    http://en.wikipedia.org/wiki/Magnetic_permeability
    http://hyperphysics.phy-astr.gsu.edu/Hbase/tables/magprop.html#c1
    If a material is Ferromagnetic or Paramagnetic, it's Diamagnetic properties are over powered.
    More details here.
    http://hyperphysics.phy-astr.gsu.edu/Hbase/solids/magpr.html#c1
    http://en.wikipedia.org/wiki/Diamagnetism
    One thing that can happen with diamagnetic materials is levitation.
    Check out the levitation clips.
    http://www.hfml.science.ru.nl/froglev.html
    SCIDB, Aug 10, 2006
    #29
  10. Uncle Ants
    Dec 5, 2003
    1,928
    East Midlands
    Oookay ;),
    Except that my reading of the wiki atrticles on all three types would suggest that vinyl is neither ferromagnetic or paramagnetc, so it must be diamagnetic (as is everything according to the article on diamagnetism).
    I'll say right now I'm no physicist, but my reading of that article would suggest that you can't make anything less or more diamagnetic by putting it on an aluminium frisby on legs with a wire coming out of it, as a material's diamagnetism would seem to be a property of the material which can't be altered. So this gadget isn't going to do anything about it.
    It would also appear to be a tiny effect next to the other kinds of magnetism. Happy to be told I'm wrong
    Uncle Ants, Aug 10, 2006
    #30
  11. Uncle Ants
    sideshowbob Trisha
    3,092
    London
    Yes, all materials on Earth exhibit at least very low levels of magnetism, and this will still be true even after they have been put through a demagnetiser.
    And, of course, we're talking utterly minimal and certainly inaudible in the case of vinyl or CD. They are not "magnetic" in the sense or to the extent that the marketing guff for demagnetisers suggests.
    -- Ian
    sideshowbob, Aug 10, 2006
    #31
  12. Uncle Ants
    eisenach
    Sep 19, 2003
    249
    ... and subjecting a cd to high intensity light doesn't make a difference either, how could it? But it does!
    Shaving off the edges of a disc is just plain stupid because we all know that's just voodoo. But it does.
    As for Auric Illuminator, that's just ... (insert the name of your own favourite cheap chemical) and is only for the terminally brain dead. CDs just give you ones and noughts, so nothing can be done to alter that. Snake oil! Pah! Oh, but it does!
    A couple of days ago at WM's I heard all three of these "treatments", stage by stage, and at each point there was a remarkable difference to the sound proffered by the disc. In total, the disc was utterly transformed. WM treated a disc of mine I know really well. At home, it's like listening to a completely new recording (if not to say "being there at the recording session").
    You wouldn't believe it if you were told about it. Hearing, though, is believing.
    Does this Furutech thing work? Don't know: haven't heard the results, but why not?
    Is it worth the money? That's up to you, but I'll tell you, I'm seriously looking at the credit available on my card, because £600 for the light thingy and £300 for the edge shaver suddenly look like seriously good value for money.
    eisenach, Aug 10, 2006
    #32
  13. Uncle Ants
    titian
    Jun 25, 2003
    973
    Switzerland
    It seems that this gadget is really causing you a serious problem otherwise you wouldn't be waisting your precious time on it and trying to find a way to justify your prejudices on it.
    Instead of waisting your time in playing kindergarden, you just could lend that unit from a dealer (collegue of yours) and try it. Then you could make a serious write up in this thread as grown up and serious people usually do. If you don't hear any difference you can then say everything negative about it what comes in your mind. I just wonder if you have prejudices for everything in the Hifi inclusive what you sell. Not really serious for a dealer...
    titian, Aug 10, 2006
    #33
  14. Uncle Ants
    6,026
    Beyond the 4th Dimension
    I have one of these units. it does what it says on the tin
    wadia-miester, Aug 10, 2006
    #34
  15. Uncle Ants
    Dec 5, 2003
    1,928
    East Midlands
    Beg pardon?? :confused: What did I do to deserve that? Please excuse me for my lack of seriousness :rolleyes:
    I don't have a problem with it at all - if people want to buy it then let them. Why do you have a problem with me not taking it seriously? I don't see why you should or why I should take it seriously.
    PS. See that winky smiley at the beginning of my earlier post ... y'see that's there to sort of indicate that no I'm not really taking it seriously - its a sort of internet etiquette thing that maybe they don't have in Switzerland. Rude individuals who make insinuations, that's a lot more serious.
    #35
  16. Uncle Ants
    taz
    Jun 27, 2004
    218
    Nr Bolton Lancashire
    this is reminiscent of the peter belt stuff from the eighties
    taz, Aug 10, 2006
    #36
  17. Uncle Ants
    mr cat Member of the month
    Jul 31, 2003
    3,375
    5
    I guess sales must be a bit slow then...:D
    mr cat, Aug 10, 2006
    #37
  18. Uncle Ants
    Paul Ranson
    Sep 4, 2003
    1,602
    An octopus's garden.
    It's easy to show whether vinyl is 'magnetic' and can be 'demagnetised'. Cut the cantilever off an old cart, adjust the arm and arm rest so that the cartridge is running at its normal height from the disc. Look at the output caused by the magnetic field on the disc and label. Demagnetise. Look for the change. Do some maths. A review that doesn't do this yet claims audibility is clearly worthless puffery.
    Paul Ranson, Aug 10, 2006
    #38
  19. Uncle Ants
    6,026
    Mr Cat,
    No I don't retail them sir, but I do use one personally
    #39
  20. Uncle Ants
    KUB3 ciao
    Feb 20, 2006
    278
    You need another hobby to balance things out into perspective, imho. :D
    KUB3, Aug 10, 2006
    #40
