listing a web sites directory
Discussion in 'General Chat' started by themadhippy, May 8, 2004.
  1. themadhippy
    1,118
    by the cross
    is there any way of listing all the pages of a web site?
    reason being a plan we need for monday is supposidly on a companys web site but the link they provided dosn't work, and as there on tour there not that easy to contact. ive tryed a few search engines without any luck,it just brings up there home page.if it makes any diffrence the home page is done in flash media .why they couldnt just fax the dam thing to us i dont know
  2. themadhippy
    5,139
    Manchester
    Well technicaly a web producer should create a site map which lists all the pages and their functions. These are more often and not never published though.
    amazingtrade, May 8, 2004
  3. themadhippy
    BL21DE3 aka 'Lucky'
    Nov 13, 2003
    422
    Cambridge, UK
    How about these bits of software, basically offline browsers that strip entire websites to your hard disk so you can browse them later.
    http://www.internet-soft.com/extractor.htm - limited trial
    http://www.httrack.com/ - GPL software
    Dunno if they'll do the trick but you could give it a go. All the best in getting it all sorted out. I'll keep my thinking hat on and see if I can come up with any more suggestions.
    Edit:
    Just found these other bits of software that might also be helpful
    http://www.pcworlddownload.com/internet/download-managers/BlackWidow.htm
    http://www.pcworlddownload.com/internet/download-managers/Infine-Capture-Flash.htm
    BL21DE3, May 8, 2004
  4. themadhippy
    1,118
    by the cross
    cheers chaps,will give that software a try,unfortunatley the site dosnt have a site map,or at least i cant find one
    themadhippy, May 9, 2004
  5. themadhippy
    sideshowbob Trisha
    3,092
    London
    Unless the document you're after is linked from one of the other pages on the site, software won't find it - basically, these programs follow every link from the home page downwards, downloading everything. So, worth a try, but it may not work.
    -- Ian
    sideshowbob, May 9, 2004
  6. themadhippy
    1,118
    by the cross
    grr could have told me before i tryed a couple of them:p ,handy bit of software though
    think i'll email them,phone them and genraly hassle them to get the plan to us first thing monday,or pay for 2 technitions to sit around drinking coffee until it arrives
  7. themadhippy
    michaelab desafinado
    6,403
    Lisbon, Portugal
    A handy and not that well-known feature of google is the "allinurl" directive which gives you all the links that google has for a particular site. In the search window type:
    allinurl:<site name>
    eg:
    allinurl:www.zerogain.com
    It will usually just show you the first link and then you have to expand the list with "show all results from <site name>".
    It won't help you though hippy - I just tried it on the site you're after and it came up with only one link.
    michaelab, May 9, 2004
  8. themadhippy
    Paul Ranson
    Sep 4, 2003
    1,602
    An octopus's garden.
    What a completely crap web site.
    What was the original URL that doesn't work?
    Paul Ranson, May 9, 2004
  9. themadhippy
    1,118
    by the cross
    themadhippy, May 10, 2004
