Low cost Subwoofery
Discussion in 'Hi-Fi and General Audio' started by Joolsburger, Mar 15, 2005.
  1. Joolsburger
    Joolsburger
    510
    Is it worth getting a cheap sub?
    Simple as that.
    I am basically very happy with my system on most music but there are times when I could do with more bottom end (my speakers are -6bd @ 40htz). Like last night for example, I was listening to "Dub plates from the elephant house" and on a track I know has deep bass lines it was all a bit too light, the bass is there but its simply too quiet.
    So to that end I was considering an MJ acoustics or REL sub for around 300-400 as a possible solution.
    Is if fair to say that at that level I'm going to have rotten boomy crap or will I be able to buy a decent bit of bass?
    Obviously I'll buy S/H.
  2. Joolsburger
    zanash
    3,826
    Notts.
    Naw....the REL's are pretty good even the cheap ones. Now if you want cheap richer sounds often has some real cr*p !! You just need to time align them so the bass wave coincides with the satalite speakers. Makes a huge difference...probably why some sound realy bad.
    zanash, Mar 15, 2005
  3. Joolsburger
    Ian J
    77
    Midlands
    At the top end of your budget you should be able to get a decent second hand REL Strata or Storm that if well set up should provide some excellent underpinning for your speakers.
    Ian J, Mar 15, 2005
  4. Joolsburger
    ChrisPa
    Nov 28, 2004
    179
    Saddleworth
    Well worth the effort for that money. I'll endorse the MJ Acoustics (I've got a Reference Pro 100). No preference over the RELs, just happened to be available for the right price (on ebay) at the time I was looking. MJ claim lower frequency responses than REL, but I suspect it may down to the way the measurements are made. ;)
    The perceived wisdom seems to be downward firing if your prime interest is music; forward firing for cinema (more "punch" which must therefore imply more high-frequency content in the signal).
    ChrisPa, Mar 15, 2005
  5. Joolsburger
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    T-bone Sanchez, Mar 15, 2005
  6. Joolsburger
    Joolsburger
    510
    that looks very familiar!!
  7. Joolsburger
    mr cat Member of the month
    Jul 31, 2003
    3,375
    5
    yeah, I'm happy with my sub for music - but for me - connecting the sub via speaker cables instead of the default phono lead in much, much better...I understand that RELs benefit using this connection...my sub certainly does.
    mr cat, Mar 15, 2005
  8. Joolsburger
    alexs2
    Dec 15, 2004
    206
    Deapends on your classification of cheap....one range I would wholeheartedly recommend is SVS.
    These run from cheap to downright expensive,and all have attracted excellent reviews on price and performance.
    The only drawback is that the company sells on via the net,and exports from the US,but the service,and delivery times are superb.
    I have a PC-Ultra,which cost £750 and simply isn't in the same league as the REL Q201E it replaced...the bass is faster,cleaner,and much deeper without any evidence of distortion or doubling.
    It easily outperforms subs costing up to twice as much(incl the B&W ASW850,bigger RELs,and M&Ks)
    If you wanted a good cheap sub,even incl P&P etc from the US,you could look at the PB10
    http://www.svsubwoofers.com/subs_pb10_isd.htm
    This thing is superb value....I'm not affiliated to SVS btw,simply a very satisfied customer.
    alexs2, Mar 15, 2005
  9. Joolsburger
    Jul 31, 2003
    3,375
    5
    if you check on AVforums.com - there is an SVS PB10 Subwoofer for sale, around 320 quid, only a few months old...supposed to be very good, tho, it's massive and grey...
  10. Joolsburger
    alexs2
    Dec 15, 2004
    206
    That measures out as 15"x19"x22" and weighs 60lbs...not hugely bigger than a REL Q201,except in depth(not just depth of bass!),but if it's anywhere near as good as the bigger ones,superb value.
  11. Joolsburger
    Jul 31, 2003
    3,375
    5
    yeah, more info here - http://www.svsubwoofers.com/subs_pb10_isd.htm
    it goes down to 20Hz (claimed), but however, it only has a single phono input - so, it may not be that good for connecting to a stereo amp - I can't really comment on that since not having listened to one, but I do know that my sub sounds much better using a set of speaker cables instead...
  12. Joolsburger
    alexs2
    Dec 15, 2004
    206
    I've got one of the PC-Ultra models,which has both phono and speaker connections.....frankly,these work much better using the phono inputs,and setting it up carefully to get the best results...read all of the info on the site(thats for Jools btw),and also use SVS's info email...the response will be very helpful and very fast also...well worth asking them for any advice you might need.
  13. Joolsburger
    angi73
    Dec 5, 2003
    268
    Essex/kent
    angi73, Mar 15, 2005
  14. Joolsburger
    maddog 2
    Jul 16, 2003
    319
    maddog 2, Mar 16, 2005
