M-Audio Audiophile 24/96 question
Discussion in 'Hi-Fi and General Audio' started by mutant, Jan 26, 2004.
  1. mutant
    mutant
    Dec 5, 2003
    108
    was wanting to buy one, and was wondering is there any way to connect to your hifi? If so, is it just line out to line in on the amp, or are there any other ways of connecting?
  2. mutant
    5,139
    Manchester
    Is is a soundcard or dac? If its a soundcard you can just connect it to your HIFI via by any standard inputs (i.e one without the phono stage).
    amazingtrade, Jan 26, 2004
  3. mutant
    Paul Ranson
    Sep 4, 2003
    1,602
    An octopus's garden.
    This card has stereo in/out on phono plugs, or S/PDIF in out also on phono plugs.
    So if you have a fantastic DAC you can connect digitally to that, otherwise direct to your amp.
    Paul Ranson, Jan 26, 2004
  4. mutant
    PBirkett VTEC Addict
    2,456
    The Toon
    Also consider the Terratec EWX24/96 as it is cheaper and is at least as good as the M-Audio (maybe better).
    PBirkett, Jan 27, 2004
  5. mutant
    joel Shaman of Signals
    Jun 21, 2003
    1,650
    The 24/96 has standard RCA L/R outputs. Mine is connected into an aux input on my amp (using highly exclusive Canare cables, naturally ;) ). As Paul has mentioned, it also has an spdif output for attachment to a D/A converter.
    I've had my 24/96 for almost four troublefree years. It works, and the software works. There are no doubt better cards out there, but I'm not interested. The one I have does the job.
    joel, Jan 28, 2004
