Mains Cable
Discussion in 'Classified Adverts' started by BlueMax, Mar 28, 2004.
  1. BlueMax
    greg Its a G thing
    Dec 30, 2003
    1,687
    Wiltshire UK
    I saw his post around 23:30. Wonder what occureth?
    greg, Jun 26, 2004
    #21
  2. BlueMax
    BlueMax
    Aug 17, 2003
    878
    South Coast of UK
    Now there is a much better cable available than the Pirelli Screenflex S2 :)
    Belden 83802
    Two 12-gauge conductors, Teflon insulation with double foil/braid shield.
    [​IMG]
    See the "TNT TTS Mains Cable" thread in the DIY section.
    https://www.audio-forums.com/as-rediect/showthread.php?t=4322
    TTS use Kimber style weaving similar to the Reference PowerKordâ„¢ by Russ Andrews; priced at £115 for 3 feet. TTS made with Belden 83802 you also get Teflon insulation, double screening and much thicker cores.
    Getting them in small lengths is a problem though :(
    BlueMax, Jun 26, 2004
    #22
  3. BlueMax
    analoguekid Planet Rush
    Nov 14, 2003
    2,189
    Paisley Scotland, UK
    Greg if you want braided mains cable check out "sid's posh power cable" on the Sid and Coke website (he's a member here) excellent and around £10 for 2m the most expensive component is the Nylon braiding about £15 for 10m from RS rest of the stuff yoiu can get at maplin.
    P
    analoguekid, Jun 26, 2004
    #23
  4. BlueMax
    Saab
    Jan 25, 2004
    1,508
    Bluemax
    yeah,but you can't go around corners faster than 3mph;)
    Saab, Jun 26, 2004
    #24
  5. BlueMax
    Wingnut
    Jun 24, 2003
    42
    Manchester
    Sorry Greg/Bluemax, with this being the Buy & Sell forum I thought I was posting off topic, so I deleted it. It appears the mods aren't as strict here then ;)
    Thanks for the advice regarding the screen, I've just finished making 4 'Merlino' cables tonight. I used SY cable rather than the perfered CY cable, due to the fact that I could find somewhere that sells SY by the meter, rather than 50m rolls as with CY.
    I'll run them in tonight and see how they sound tomorrow - far too late to try them now! :eek:
    Wingnut, Jun 27, 2004
    #25
  6. BlueMax
    BlueMax
    Aug 17, 2003
    878
    South Coast of UK
    Four Merlinos! :)
    Mains cables need a lot of burning in. So give it a few hours before evaluating.
    I use the main cable as an extension cable for couple weeks in the kitchen and power fridge/freezer, washing machine, etc before cutting to short lengths for hifi. Last year I did A-B testing using the cables from the same reel; to make sure this 'breaking in' phenomena is not all in the mind :D
    BlueMax, Jun 27, 2004
    #26
  7. BlueMax
    Wingnut
    Jun 24, 2003
    42
    Manchester
    Yeah, I figured that even if they didn't sound good, they look mighty priddy :D
    Wingnut, Jun 28, 2004
    #27
