Mana Audio update
Discussion in 'Hi-Fi and General Audio' started by Heuer, Oct 5, 2005.
Thread Status:
Not open for further replies.
  1. Heuer
    mick parry stroppy old git
    Jun 21, 2003
    557
    Swindon
    Chaps
    I think most people who have tried it would agree that a Mana wallshelf improves the sound of a LP12 albiet at the cost of visual taste and the increased risk of losing your wife/partner.
    A high percentage of Mana owners run Naim equipment and the modern stuff is less dependant on racking. so Mana has little or no effect on the sound of the newer stuff but may have improved the old stuff.
    Possibly it has a role for £99 CD players has advocated by Mr Pig. However he also suggested that Wendy houses improved the sound also with rubbing the painted finish off a RB300, so he does have a credibility problem. JW would do well to quietly remove Pig from the forum. In the old days Pig was totally obnoxious and now he is just repeats the obvious.
    Bub has old Naim so possibly his system will benifit from Mana. However if I was in his shoes, I would sell the lot including the Mana and buy the new Naim stuff.
    Mana still has a niche in the market but a significantly reduced one. Times change and if we don't change we die.
    Regards
    Mick
    mick parry, Oct 7, 2005
    #81
  2. Heuer
    Barnie
    Nov 22, 2003
    136
    Up a hill
    Being pe-occupied sharpening one's axe does tend to have this effect...
    You appear to be saying that the Naim Fraim is now useless, due to the release of Naims new range?
    Barnie, Oct 7, 2005
    #82
  3. Heuer
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    sensayuma - just found out what it means, had a chuckle at that!
    T-bone Sanchez, Oct 7, 2005
    #83
  4. Heuer
    fox
    Nov 21, 2003
    85
    Seattle
    Its not as grave as you think it is. I returned the Ninja LP12 and upgraded to the Orbe some 2-3 years before. I'd just never taken it off Mana until after I got my ATCs in Oct '04. I Stayed with Mana under them getting used to changes and formulating theories and ways of testing them until 1 Feb '05 when I tried a side-by-side comparison (note: you do need to have speakers to sit on Glass to be considred correct for the Mana purists, but Phase 10 in stages should account for something): yet it did nothing for me. I think 4 months is enough time to see wood for trees don't you?
    Basically please don't assume I've not done any reaserch into this: Surfaces can and do make slight changes and if any support does work it works by different mechanisms for Turntables and Speakers and Amplifiers and needs to be proven/debunked accordingly.
      File size:
      65.2 KB
      512
    fox, Oct 7, 2005
    #84
  5. Heuer
    Curt
    Jun 22, 2003
    164
    Look at the size of those bastards :)
    Hi Foxy hope you are well mate
    Curt
    Curt, Oct 7, 2005
    #85
  6. Heuer
    anon_bb Honey Badger
    May 30, 2005
    2,804
    I do with the speaker platforms but not for the deck stand - except maybe once or twice a year. The table has a solid top so you wont get a puncture.
    I think saying the amazon and vpi are conceptually similiar is a bit of a jump - both black and made of acrylic? What type of decoupling did the vpi use.
    anon_bb, Oct 7, 2005
    #86
  7. Heuer
    May 30, 2005
    2,804
    Its as I thought - a stand of the same height as phase xx sounds exactly the same and the "mana effect" is just the effect of raising the unit from the floor. I guess that kind of nonsense is the kind of over milking I was referring to that has helped drive them out of business.
    #87
  8. Heuer
    griffo104
    Dec 22, 2004
    362
    West Midlands
    I haven't used the Townsend platforms but do have 2 voodoo air platforms - similar concept but wooden.
    The Orbe sits on one - I found this improved soundstage and bass and took a slight edge of the treble which the original torlyte platform gave it. Maybe having the motor suspended via the air interface helps it in this respect.
    I also have the PSU on a psu voodoo which also seems to have made a slight difference.
    Similar to the Townsend, I tend to pump the platform up maybe a couple of times a year.
    The Voodoo makes a HUGE improvement under the Denon DVD2900
    griffo104, Oct 7, 2005
    #88
  9. Heuer
    joel Shaman of Signals
    Jun 21, 2003
    1,650
    Jaw-dropping, undoubtably.
    joel, Oct 7, 2005
    #89
  10. Heuer
    griffo104
    Dec 22, 2004
    362
    West Midlands
    Damn right.
    The Denon is very fussy about what you put it on - even more so than an LP12 :eek: IMO
    And it has been on my Mana - modern equipment, not Linn or Naim and, erm, it didn't like it one little bit.
    #90
  11. Heuer
    Bradders
    Jun 7, 2004
    158
    London
    Hi Fox, I would never assume anything - and it sounds like you have arrived at your set-up after much hard toil; I'm glad it works for you.
    I'm happy with my system & see no reason to change it, every experience I've had with mana leads me to believe it has a very positive effect on my system. I think we're coming from slightly different angles as I'd never have the multi, multi, multi-phase set-up that you used to have & so haven't invested so much time & money in it.
    I don't feel the need to prove or debunk any theory; although it was actually you on Pink Fish who prompted me to try my system off the mana to see how it was influencing the components - having tried this I'm satisfied it works with my relatively modern gear.
    Bradders, Oct 7, 2005
    #91
  12. Heuer
    Sir Galahad Harmonia Mundi
    Nov 4, 2004
    586
    Paris
    Thanks Joel, I'm learning new words on ZG. I thought it was "undoubtedly". How wrong can you be? ;)
    Sir Galahad, Oct 7, 2005
    #92
  13. Heuer
    1,964
    Well if they have gone out of business, the whole does it work argument is a bit moot eh?
    garyi, Oct 7, 2005
    #93
  14. Heuer
    michaelab desafinado
    6,403
    Lisbon, Portugal
    It is - indubitably ;)
    michaelab, Oct 7, 2005
    #94
  15. Heuer
    Nov 4, 2004
    586
    Paris
    Without a shade of a doubt...
    #95
  16. Heuer
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    It's "shadow" not shade!
    Dev, Oct 7, 2005
    #96
  17. Heuer
    Nov 4, 2004
    586
    Paris
    #97
  18. Heuer
    fox
    Nov 21, 2003
    85
    Seattle
    fox, Oct 7, 2005
    #98
  19. Heuer
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Hey, I won! 159,000 to 334.
    Thanks Fox.
    Dev, Oct 7, 2005
    #99
  20. Heuer
    MO! MOnkey`ead!
    4,881
    hmmm....
    From the thread about Meadowlark seeming to go under....
    (https://www.audio-forums.com/as-rediect/showthread.php?t=8270&page=1&pp=20)
    and....
    MO!, Oct 7, 2005
Thread Status:
