After I have managed to successfully repair the WC pump for the wife in the weekend with out resorting to any books or instruction other then careful observation, I thought I will try to make a ariel lead with a coaxial to BNC plug. I thought if I chop off on end of the coaxial plug and replace it with a BNC version that would be the simplest. However, since I don't have a crimp tool or a glue gun, errr.....sorry, solder, I thought I just buy this screw on version. [IMG]http://www.maplin.co.uk/images/Full/1563i0.jpg[/IMG] [URL]http://www.maplin.co.uk/Module.aspx?ModuleNo=1563&TabID=1&source=15&WorldID=&doy=7m4[/URL] Got it back and after studying it with care I am never so clueless how to proceed. It says at the website all you have to do now is, ''strip outer sheath then fold the screen back over the outer sheath, then strip the inner sheath and screw the plug on.'' Sounds true good to be true. Any help from you lot would be appreciated. Maybe it is a case of just cut the cable and study the inner construction to understand which bit go where.
