MC2 Audio. Any users or experiences?
Discussion in 'Hi-Fi and General Audio' started by vincula, Mar 21, 2011.
  1. vincula
    vincula
    Aug 12, 2009
    209
    Denmark
    Hi guys,
    A friend of mine's considering buying a pair of these:
    http://www.mc2-audio.co.uk/mc750/
    He wants to bi-amplify his huge JBL 4430 with them. AFAIK MC2's well-respected within the prof' audio world, but what about using them in home enviroments? Any users or experiences?
    Regards,
    Vincula
  2. vincula
    1,118
    by the cross
    myea,nothing special,mid range pa amp,although they seem popular in hifi circles, I'll stick with lab gruppen fp10000 q's thanks
    themadhippy, Mar 22, 2011
  3. vincula
    Tenson Moderator
    Nov 12, 2003
    5,947
    Seem like well built amps to me, but I would not want an amp with a fan in my home because of the noise.
    I wonder if he really needs that kind of power for a home system? JBL are usually quite sensitive.
    If it were me and I wanted massive power I think I'd mono-block the bass with Alesis RA500 amps (500watts each mono-block mode) and get a Cambridge Audio Azur 840W for the higher range. If you have the cash then it would be nice to run a CA 840W bridged on each bass section. Three of them in total then. They are superb amps at the cutting edge as you can expect when designed by Doug Self and cost about the same as the MC2.
    Tenson, Mar 22, 2011
  4. vincula
    Haselsh1 Shaun H
    Nov 6, 2008
    249
    Lincolnshire
    I have used pro audio amplifiers in a domestic environment before because of their big, gutsy power but ultimately, they just sound too coarse and rough for me. The best I ever used was a Samson Servo 550 which was just so effortless in the bass through Castle Harlech MkI speakers. I'll never forget the sound of India Arie singing 'Brown Skin' through that bloody amp. Truly gorgeous.
    Haselsh1, Mar 23, 2011
  5. vincula
    Smithy
    Mar 10, 2006
    59
    My MC2 650 doesnt sound coarse and rough ,I would be surprised if it wasnt bettered by £5000 of labgruppen but for £350 (used)I am not too fussed. Even in a smallish room fan noise isnt an issue for me.
    Smithy, Mar 23, 2011
  6. vincula
    RobsterD
    Oct 13, 2004
    70
    Soton,Hants
    just got a MC450 to power some BD15 bass drivers in my horns.
    Chose in preference to some nice HiFi amps Adcom,Parasound etc.
    Look forward to delivery to test out a Trinnov ST2 active crossover config courtesy of Keith@Purite.
    RobsterD, Mar 23, 2011
  7. vincula
    vincula
    Aug 12, 2009
    209
    Denmark
    Thanks a helluvalot for the feedback, mates. I'm learning a lot here, clicking around and checking out all those brands.
    Keep it coming:D! I'll pass it on.
    Regards,
    Vincula
    PS. Unfortunately I'm myself a valve nostalgic sorry sod. Though I love when my friends choose to go down the gutsy road, so that I can jump around myself in their living rooms after a couple of pints. Just for a short while, it's even exciting :MILD:
    vincula, Mar 24, 2011
  8. vincula
    cooky1257
    Aug 30, 2007
    797
    FWIW I use an MC1250 and MC750 on bass/mid and hf duties.
    They are excellent amps, smooth mid and airy top, bass grip, depth, clarity and sheer drive that pisses all over most, owned in pref to Chord, Bryston and Naim 250's.
    There was a great thread on here a few years ago about these amps.
    They have Klark Tecknik pedigree, are usually partnered with XTA signal processing in the pro world so top end..very top end.
    The fans can annoy some in a home environment but I live happily with mine.
    cooky1257, Apr 1, 2011
