So when we measure a signal we look for distortion vs the source, so I'm thinking what is the correlation between taking a stereo signal and modifying it to place one element of the music in a different location spatially. You know just nudge it half way across the soundstage via mixing tools. What level of distortion would that change represent compared to the original signal. If we are always going on about stage depth, width, height, space round instruments and all that bollocks why has no one ever done something really obvious like relocating one of the lead instruments in an orchestra and measure the difference in terms of the commonly used measurement sets? I'm sure we can all hear the difference in moving a player within the sound-field, but I'm wondering if our ability to home into a narrow range of sounds within a huge sound-field and apply our unique processing power to temporal/spatial cues to define a 'position' for soemthing in the mix isn't actually beyond the capability of our measuring tools. kind of like. "Measurement tells us everything", yeh well measure me the bit that tells us whether the guy on the trumpet is using an aluminium or rubber mute.
