Hi, I visited Nick (Brionbiovizier) the other day and was watching him and Simon (Tenson) measure and correct the room using a DEQ2496, I have a couple of questions about what to use to do the same with my system. I plan on using a DEQ as the EQ, but I know I can get better results by using PC software to do the measurement then feed the results into the DEQ. I'm planning on using ETF software for measurement, a Behringer ECM8000 mic and MIC100 mic preamp. Simon was using a unidirectional mic to measure each speaker individually at one point, is this essential or can I get reasonable results using just the ECM8000? I mean can I usefully measure each speaker individually with a omni mic? I know measuring each speaker individually first is the right way to go about this, then once they are individually corrected I will then correct both together at the listening position. As for PC hardware, I presume the ADC and input stages in a laptop have a ropey and pretty useless response, I looked at Behringer UCA202 and FCA202 which are USB and firewire (respectively) IO boxes, basically USB soundcards as far as I can gather. Would these suit my purposes? The USB one is half the price of the firewire version, would I need the faster firewire connection or would USB do? I'm guessing it will as sampling 16/44 is about 690kbps/86kBps which is easily handled over USB. The only thing that occurs to me about using these is that it may be better to use the DAC and ADC in the Behringer DEQ2496 (which will be the DAC in use in the system when playing music) to do the measurements - would this be significantly better? If so, since the UCA202 only has digital out, I presume I need some sort of USB or firewire SPDIF I/O box which can take a digital in from the DEQ and feed it to the PC - any suggestions for cheap and reasonably good boxes that serve this purpose? Thanks. Paul
