Dunno whether this'll interest anyone here, but I thought I'd post it anyway... This little beast is a 40 watt monoblock power amplifier, from Meier Audio, the company that usually produces headphone amplifiers. They cost about £1,000 per pair, so they are not cheap, but claim to offer performance heard only in amplifiers costing several times their cost, despite the relatively modest 40 watt rating into 8 ohms... [URL]http://home.t-online.de/home/meier-audio/poweramp1.htm[/URL] [IMG]http://home.t-online.de/home/meier-audio/bilder/frontpoweramp480.jpg[/IMG] [IMG]http://home.t-online.de/home/meier-audio/bilder/pcb1poweramp480.jpg[/IMG] [IMG]http://home.t-online.de/home/meier-audio/bilder/sidesideampset480.jpg[/IMG] [b][u]Technical details[/u][/b] 2 inputs ( AC/DC coupled) AC coupled input bypass Continuous output power: 40 Watts @ 8 Ohm 75 Watts @ 4 Ohm 100 Watts @ 2 Ohm 75 Watts @ 1 Ohm Gain factor 19 dB. Input impedance 27 kOhm Gold-plated input jacks. Silver plated loudspeaker connector (Neutrik). 225 Watts toroidal transformer (Talema). 110V and 220V versions available. Built-in mainsfilter (Schaffner). Built-in groundloop breaker. Schottky rectifying diodes in the power supply. Double and fourfold regulated voltage lines. Low impedance electrolytic buffer capacitors (Panasonic). Total Buffer capacity 64.000 uF. Polyesterfilm bypass capacitors in the power supply. Polystyrol and polypropylen (Vishay) capacitors in the signal path. Metalfilm resistors in the signal path. Double sided PCB with 70 um copper. LM6171 opamp for signal control biased into class-A using a LM334 current source. 4 LM1875 buffer amplifiers in parallel. Star-grounding. Short short signal paths. Signal paths and signal path components at the bottom side of the PCB for maximal shielding. Sturdy aluminium enclosure with anodized back plate and anodized high power heatsink at the front Laser engravings. Weight: 5.6 kg. Size: 21.5 x 33.8 x 8,4 cm
