Meter for a beginner?
Discussion in 'DIY Discussion' started by chiba, May 20, 2004.
  1. chiba
    chiba
    Jun 25, 2003
    9
    Chiba, Japan
    Starting to quite enjoy DIY, and in preparation for making something slightly more substantial, I'd like to get a meter. I've seen all manner of quite cheap digital ones, but the resident electronics guru at work said that they're "of random accuracy", and recommended that I get a secondhand Fluke instead, which I could then sell on later for little loss if I wanted to upgrade (or realised this hobby wasn't for me). Had a quick look around, and the 17x range seems to do everything I'll need. I want to build two headphone amps as first projects, a portable one first, and then a more substantial one for home. Any comments?
    chiba, May 20, 2004
  2. chiba
    Chea Johndle Bizarre Serpent Foomaster
    217
    Foo Central
    I bought a really cheap £4-99 digital multimeter, it's a DT830B and its fine for the majority of measurements.
    I also have a 6 digit bench multimeter for the more serious measurements.
    If you look around you can pick up some good Fluke one's quite cheap.
    Regards
    Chea Johndle, May 20, 2004
  3. chiba
    217
    Foo Central
  4. chiba
    1,118
    by the cross
    whilst flukes are mighty fine meters there a bit of over kill ,ive found 2 of those cheapo meters ideal and fairly accurate,ive also a fancy meter that does everything but i hardly use it,more usefull is an oscilascope,ive one of the £100 lcd model,direct read out of voltage,either rms or peak and frequency,and you get to see a pretty wave form
    themadhippy, May 20, 2004
  5. chiba
    BlueMax
    Aug 17, 2003
    878
    South Coast of UK
    Will an oscilloscope show how clean a mains supply is?
    BlueMax, May 20, 2004
  6. chiba
    1,118
    by the cross
    possible,depends how high a frequency you wish to measure up to,mine goes up to 10Mhz,it will show wot the base frequency is,and wot th voltage is . make sure its got a suitable voltage rating though .o and also the scopes signal earth maybe at mains earth,connecting it to mains neutral may give some misleading results
  7. chiba
    Lord .
    Dec 21, 2003
    166
    East Sussex.
    DMM.
    Go and buy GW26D at Maplin.
    A reliably accurate (ignore your sniffy workmate!) DMM that also measures Capacitors and Inductors and is thus ideal for audio. Not under a tenner, but should last you a very long while, having entered the catalogue number above into the Maplin website I see that it is under 3 tenners...
    Model WG020 Price: £29.99 Valid until: 12/06/2004 Save: £20
    A signal generator and oscilloscope would indeed be the next step for thee and me, but one step at a time... :cool:
    EDIT: Re your reply below... ooops! Didn't spot your location, but I imagine that the WhiteGold WG020 is manufactured closer to you than I anyway! If you can spot it amongst the cartoons it is worth considering. :)
    Lord, May 22, 2004
  8. chiba
    chiba
    Jun 25, 2003
    9
    Chiba, Japan
    Maplin. Hmm, kind of a long way. :) I think I'll get something cheap and cheerful for the time being. Plenty to choose from, so just pick the one with the cutest cartoon characters in the ads. Usually works.
    chiba, May 22, 2004
  9. chiba
    joel Shaman of Signals
    Jun 21, 2003
    1,650
    Chiba,
    You need to go to Radio Kaikan in Akihabara. You will find something to suit your needs and budget there.
    joel, May 22, 2004
  10. chiba
    chiba
    Jun 25, 2003
    9
    Chiba, Japan
    Joel - cheers. Is it a tool shop? There are three tool shops that I know, but to be honest I don't really bother with names, just tend to navigate by 'across from the place that does second hand Compaq kit' or 'round the corner from the place that looks like a dodgy anime shop but in reality sells really cheap DVDRs', etc. :eek: I often go with a more logical mate though, so I'll ask him if he knows it. :)
    chiba, May 22, 2004
