Microphone charectorists
Discussion in 'General Chat' started by amazingtrade, Nov 28, 2003.
  1. amazingtrade
    5,139
    Manchester
    I am writing up my report for computer audio and I have lost my lecture notes which had lots of writing on it about micrphones. I can remember most of it, but I can't remember what the differences are between condesnor and moving coil (dynmanic) microphones.
    So does anybody know roughly what each one sounds like and which type is best for different type of recordings?
  2. amazingtrade
    scrosland --
    Jun 23, 2003
    20
    England
    scrosland, Nov 28, 2003
  3. amazingtrade
    Hex Spurt
    Jun 24, 2003
    432
    Cheshire
    I hope you're planning to use spell check before you submit the article ;)
    Dynamic mics work like a speaker in reverse. Sound waves move a diaphragm to which a coil attached. The coil moves past a magnet, this creates an electrical current to flow. There's a lot of weight to move with this type of design. They are less sensitive but can work better for high spls. Drum mic'ing is a good example.
    Condenser mics work a bit like electrostatic speakers in reverse. A light weight diaphragm is suspended over a back plate. Charging both plates sets up an electrical field. Sound waves cause the plate gap to change. This generates an electrical current. Because the diaphragm is light it has less inertia. This means it reacts fast than a dynamic mic so is more sensitive to subtle sound pressure changes. In general this type of mic would work better for high frequency sounds.
    Hex Spurt, Nov 29, 2003
