Mini-ITX music server / PC
Discussion in 'Classified Adverts' started by aquapiranha, Sep 11, 2010.
  1. aquapiranha
    aquapiranha
    Nov 21, 2004
    248
    Hi. I built this unit to use as a music server, but I no longer need it.
    It is built around a VIA C7 processor @ 2 Ghz. I have fitted a brand new 500Gb SATA HDD and installed Windows 7 professional (for testing purposes only).
    It is fitted with 1Gb of RAM, the maximum the board will address. Also, the original PSU has now been replaced with a low consumption 80W unit that uses an external in-line box and an internal smoothing circuit. I have also fitted a high speed DVDRW (SATA). Also, I have changed the CPU fan for one that is quieter than the original. The case used is this one...
    http://www.xcase.co.uk/X-Case-Atomic-Cube-Black-With-Psu-p/case-xc-atomic-cubebk.htm
    The board is this one..
    http://www.jetwaycomputer.com/J7F5M.html
    A couple of things.. the 'flap' covering the DVD draw sticks open sometimes, I have not got round to sorting it! The power connector for the new PSU I have fitted to the blanking plate for the PCI slot - so if you want to fit a PCI card, you will have to refit it elsewhere. The unit is running W7 well, if not at lightening speed, as you might expect! I installed Vortexbox to use it as a server, or you could use FreeNAS etc.
    The unit is working perfectly, and still have the plastic wrapping on the case. I would prefer NOT to post this if possible.
    I would hope to get £100 for the PC.
    **WILL SWAP FOR A BERESFORD OR SIMILAR WITH VOLUME CONTROL**
    Thanks.
    The 'mark' you can see on the right edge of the caes is the plastic wrapping, not the case itself.
    [​IMG]
    [​IMG]
    [​IMG]
    I still have the original box and packaging for the case.
