Minidisc recommedations please
Discussion in 'Hi-Fi and General Audio' started by Goomer, Sep 30, 2003.
  1. Goomer
    Goomer
    Sep 1, 2003
    598
    Howdy
    My minidisc walkman - which I have also been using in my home system -has just died, and I am now looking to replace it with a full size one to take over home recording facilities.
    I've seen various Sony models around the £100.00 mark but am looking for something a bit more substantial and with more edit options - the Sony ...980 looks good, although I've yet to hear it - for a reasonable price.
    So...any recommendations for models and where to get them for the best price?
    Thank you all in advance.
  2. Goomer
    nsherin In stereo nirvana...
    728
    Portsmouth, UK
    For home use, I've been using a Sony MDS-JE480. It's a budget deck, with an RRP of £130. It does a decent enough job for the money. It only has Optical In and no coax connections.
    However, if you've got more money to spend, then either the MDS-JE780 (with Optical In/Out, plus I think NetMD functions) at £210 is worth looking at, or the MDS-JE980 - I'd love one of those decks, but funds will not allow! Personally, if you've got the money for the 980, I'd go for it!
    nsherin, Sep 30, 2003
  3. Goomer
    Aug 31, 2003
    854
    SE Norway
    On a general point I like the Sonys. I use an old 520 and find it convenient for editing the speech out of recorded radio shows, etc. Just one point: if you already have a PC keyboard (or even if not) I would get a model that allows one to be connected so that you can type in track names etc a lot quicker. Even if it is netMD this is better than being dependent on a whole PC in the neighbourhood.
    SteveC
    SteveC, Sep 30, 2003
  4. Goomer
    Goomer
    Sep 1, 2003
    598
    Sorry if this sounds dumb, but does the above mean that you can connect a PC keyboard directly to the MD deck for labelling purposes, without the need for any special adaptors or a PC itself?
  5. Goomer
    Aug 31, 2003
    854
    SE Norway
    Yes, I believe so, though my own deck doesn't have that capability, and I miss it! Otherwise, labelling is reasonably quick with the standard controls on these Sony decks - but the remote keypad is laid out alphabetically, not QERTY, and the front-panel possibility is done with a rotary knob for the alphabet - so I always felt a PC-keyboard connection would be ideal, if you like to label tracks individually.
  6. Goomer
    2,641
    Exeter (not quite Cornwall!)
    Yep - I use a 940 and a cheap PC-Line keyboard - no problems at all re labelling, though I rarely use MD now unless during mastering to a CDR (it's easier to take the performance hit of MD than piddling around with editing on CDR).
    The 940 is a stunning machine - I'd expect the 980 to be even better. I also use an old 530 which in itself is fairly nice, but not a patch build or quality wise on the 940 :)
    domfjbrown, Sep 30, 2003
