Mission 773e (Light Cherry)
Discussion in 'Classified Adverts' started by technobear, Jun 27, 2003.
  1. technobear
    technobear Ursine Audiophile
    Jun 22, 2003
    2,099
    Glastonbury
    SOLD: Mission 773e (Light Cherry)
    SOLD
    Mission 773e in Light Cherry wood finish.
    Complete with box, grilles, spikes, manual.
    Nearly 4 years old (so well run in :D ).
    Happy to demo at technobear towers or locally (Somerset).
    Buyer collects.
    £150 ono.
    From Mission:
    PRODUCT INFORMATION GUIDE
    Mission 773e Loudspeaker
    Construction
    Enclosure: 15mm high density particle board.
    Veneer: Real wood veneer supplied from sustainable sources.
    Baffle: High grade profiled 38mm MDF.
    Ports: Anti-turbulence port tube.
    Grille: Acoustically transparent.
    Damping: Fire-retardant polyurethane foam.
    Electrical
    L.F. Unit Twin 130mm (5¼") Aerogel membrane bass/mid units.
    H.F. Unit 25mm (1") ferrofluid-cooled, viscous-laminated fabric dome with neodymium magnet.
    Cross-Over network:
    L.F Unit Phase corrected 1st order.
    H.F Unit 2nd order.
    Terminals Multi-way, biwirable binding posts.
    Specifications
    Enclosure Type 2-Way Reflex Loaded, floorstanding
    Nominal Impedance 8 Ohms compatible
    Frequency Response ±3dB 50Hz-20kHz
    Sensitivity SPL/m/2.83V 88 dB
    Cross-Over Frequency 3 kHz
    Effective Volume 22 Litres
    Recommended amplifier power 25 - 130W
    Cabinet Dimensions (H x W x D) 850 x 172 x 267 (mm) 33.5 x 6.8 x 10.6 (inches)
    Finishes Graphite black, Rosewood & Cherry real wood veneers
    Features Benefits
    Ultra rigid particle board cabinet - Significantly reduced cabinet coloration.
    Profiled front baffle edges - Reduced edge diffraction giving outstanding stereo imaging.
    38mm MDF front baffle - Strong, stable platform for drive unit mounting.
    Integral adjustable base spikes - Effective cabinet de-coupling and improved stability.
    Aerogel membrane mid/bass units - Low mass for excellent detail resolution, rigid for increased dynamics.
    Twin bass drivers - Provides large bass dynamics with clarity and precise control.
    Phase correction plug - Better off-axis performance, smoother frequency response, reduced cone mass and removal of dust-cap resonance.
    Leaf-sprung HF isolation system (DIS) - Tweeter unit is isolated from sonically degrading baffle vibrations.
    Viscous-laminated fabric dome HF unit - Highly refined, ultra-low distortion high frequency unit.
    Simple cross-over network - Minimised signal path between amplifier and speaker resulting in increased detail resolution and an easy amplifier load.
    Setting Up
    • RUN IN for at least 24 hours before serious listening.
    • Position within 10cm – 30cm of rear wall.
    • Use good quality speaker cable.
    So now you know :D
    Chris
  2. technobear
    Jun 22, 2003
    2,099
    Glastonbury
    These have now been sold.
    Chris
    technobear, Jul 2, 2003
